Ford Testing New Suspension for Performance Trucks?
Stampede.Offroad
SD
junk
Wearing current-generation Raptor bodywork, wheels, and tires, this mule for the next-gen F-150 is also sporting significant rear suspension camouflage. Plainly obvious is the lack of rear leaf springs, which have been found under the Raptor since it was introduced for 2010. Instead, we see a Panhard bar and pivot bolt, suggesting, the 2021 F-150 (or at least the F-150 Raptor) will get a five-link rear suspension like its rival, the Ram 1500.
http://www.trucktrend.com/news/1909-spied-2021-ford-f-150-raptor-camouflaged-suspension-bits
Ford Bronco Ford Testing New Suspension for Performance Trucks? 2021-ford-f-150-raptor-exterior-disguised-rear-suspension-02
The rear of the Bronco mules have been heavily camouflaged, were they hiding something similar? The Watt's link that current gen Rangers and Everests use doesn't really seem to offer much articulation.
Ford Bronco Ford Testing New Suspension for Performance Trucks? 2016-Ford-Everest-Cutout-7-990x660
Stampede.Offroad
Stampede.Offroad
SD
junk
A 2019 Ranger example here starting at 7:11
Some of the disparity is attributed to a 'purposely flexible' frame on the Tacoma, and this level of rigidity might do well for a pickup meant to do work with heavy payloads and towing, but if a Bronco was sharing the Ranger configuration it wouldn't seem favorable for articulation.
JimmyDean
Louisiana
82 Bronco, 513 ci; 71 mach 1, 351C; 06 F-250, 6.0; 56 800, 172c.i. gas
I would rather have zero articulation in the frame, and have it all in the suspension. For a pickup, I don't mind less articulation as that lowers payload and towing. But on the Bronco, screw the payload, I want as much f'in travel as they can fit.
Tslater1989
Tyler
Central Michigan
2001 f150, 2016 explorer, 97 f150
Believe it or not, a watts link suspension can get a lot of flex. The limits on the Everest are the actual springs. The center pivot can be made longer, allowing higher ride height and overall travel. Rock crawling is more about individual wheel "droop" than overall travel of the entire axle. Google image search watts link articulation jeeps and you will see its entirely possible to get a lot of movement
BroncoBuyer
Phoenix AZ
GMC
Geezus!! Talk about upskirt photography. I’m guessing that photographer carries a creeper at the ready and has grease under his nails. No photographer I know would ever get dirty to get the shot like that.. lol!
Motorpsychology
Prescott, Wisconsin
'18 Ford Escape '09 Mercury Mariner
...Unless commissioned by Ford to take "leak" ;) shots...
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
BuckWildOffRoad
Austin
Arkansas
Badlands Bronco, King Ranch F250, Taurus SHO
I though we've already seen the rear on the Bronco and it is either struts or coilovers / we couldn't see any coil springs (or leaf) under there.
This thread is from September 2019. We have seen the undercarriage of the Bronco since this was posted. ?
Dads_bronze_bronco
evoaire
Evoaire
VA
maybe a bronco
Another peek under the new coil sprung F150-Raptor. How much in common will the coil sprung rear of the BroncoBronco have?
https://www.autoblog.com/photos/next-generation-ford-f-150-raptor-suspension/#slide-2172347
Is the above Ford pic a set up of watts link or a Panhard.
Love this explanation of the Panhard.
dmtndan
1991 Silverado, 2014 Malibu
Looking at it I think that is a safe bet,
What would this mean for articulation purposes?
