Ford Performance tune - updating versions?
Easy-v
U S A
BadSquatch
Does Ford update the tune over time?
Is there a version release reference anyone has been able to track down. I know when I had my Bronco flashed earlier in the year, as an example, the axle flash was optional. I believe now by default it installs the updated axle code.
How often do people check for updated tune?
TommyHawk
Thomas
Columbus, OH
2014 Ford Fusion, 1997 GMC 1500, 1965 Ford Mustang
Oh, great question! I'm following this because I'm curious as well if I need to download and re-flash every so often?
JFelty
Stroppe
Minnesota
Lincoln Corsair Hybrid (Plugin)
Stroppe
I have the same question.
ultimateone
Boston
2024 Badlands
Is there no Tune Manager application like other tuners?
edit:
Direct from Ford
***NOTE*** ProCal 4 software only available for Windows 7 or greater. Will NOT work with Windows 10 in "S Mode".
***NOTE*** ProCal 4 tool receives periodic firmware updates for greater usability and additional features. Please connect tool to PC periodically to receive the updates automatically.
WildtrakBronco
Pennsylvania
2022 Bronco
edit:
Direct from Ford
This addresses the tuner itself, but leads me to believe that the tune for the vehicle does not receive updates. Otherwise, they would recommend updating or having the tune file re-flashed to the Bronco.
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
Because the tune is C.A.R.B. certified and the amount of money involved to re-certify any changes to the tune, I would say the tunes do not get updated, except for some extraordinary circumstance.
Ducati1098
The tunes do get updated. I had a PCM OTA update that kept failing the other day. I’m assuming because of the programmer.
So I put it back to stock, updated the programmer itself which also downloaded a newer tune file.
adcam
Mando
2025 Stroppe
There are updates. That’s why there is an “update” button when you connect your Procal to your windows laptop. I check at least every 3 months. You will need your fordperformance.com user and password plus the original unique number/letter combo that came with the tune. Last version I checked it was 2.118.
BTW, I installed the tune myself. Not sure for those who had them dealer installed. Did you bring your laptop? Did the dealer use their account to install?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
They logged in using my login and a temporary password that I setup. I changed the password once I had the vehicle back.
I guess I’ll have to get Procal on my laptop and check in periodically.
Aonarch
Jack Hoff
MT
I check every three months or so for updates, by plugging the tuner into my PC.
CatMonkey
Lafayette LA
Firmware updates update the flash tool. These updates happen rather routinely. That doesn't mean the calibration has changed.
meh
23 Eruption Green Wildtrak
Just following up on this - if we get a tool update, how do we know if there is a tune update? DO we have to reflash each time or will the car tell us if we plug it in?
I ask because I just got a tool update.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
There was another thread on this recently, there was a new flash available. Likely just to add support for additional model years, but who knows, they don't exactly put out release notes.
redone17
Cold Spring, NY
I believe it was due to releasing the new gearing upgrades.
