Ford Performance rear axle assembly
Jms1
Oregon
2022 Badlands
Has anyone ordered one of these yet? I need a replacement housing and thought I would try it. It appears to be less expensive than purchasing a housing and swapping the internals over. If anyone has any insight please let me know. Thanks
Bronco 2021-2023 M220 Rear Axle Assembly 4.46 with Electronic Locking Differential M4000446B
https://www.ford.com/product/bronco...-welectronic-locking-differential-p2963964262
NORCALGXP
Sacramento, California
2017 Raptor
Found it for less. Ford dealer known for excellent prices. $2,222.53 Good luck
https://www.levittownfordparts.com/sku/m-4000-446b.html
From the website
"For Broncos NOT equipped w/E-locker from the factory, see M-14489-BR for wiring/switch kit. If changing axle ratios M-9603-B23 or M-9603-B27 are required for module and speedometer recalibration. Note: ***FRONT AND REAR AXLE RATIOS MUST BE THE SAME***"
I've got that exact same one installed in mine right now, although it was a Black Diamond takeoff.
Yeah - long been the common advice around here, if you are looking to upgrade to a locker, or regear and have the welded ring gear -- this is a better route to go.
Jms1
Jms1
Oregon
2022 Badlands
Thank you for the responses. I have a Badlands, but my axle housing is bent due to an individual hitting my drivers rear tire. This looks to be an exact replacement. Thanks
ZapMflash
jason
Downey CA
2021 Bronco Base(ish)
I bought one a year and a half ago and installed in my Base. Best price I found on them was through Jegs. It just bolts in and works. I wired the locker through a manual switch and relay. Works as it should.
Valhalla
Valhalla
Chattanooga Tn
Dana HD rear is an idea also, just be done upgrading... too bad you don't want the 4.7 gear... might've made you a deal...
White Zombie
jim
North Dakota
22 bronco
Too bad your too far away or I would be interested in taking you up on the offer for the axle. Would you happen to have the front available also?
Valhalla
Valhalla
Chattanooga Tn
I will be doing both and selling as a set. I did not get the money for it last year as my finance is tied to performance. I will be doing it in '26 but if i had a buyer lined up for my stuff I'd pull the trigger after our yule tide ride.
