Ford Performance Axle Swaps - how much labor required?
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
Just in case you haven't seen it, (the search function can be a bear sometimes) here is a link to my rear axle swap guide. It might help you determine if you have the want/ability to do it yourself. I did it on the floor with jacks and jack stands. Only specialty tool I would recommend is a good impact wrench. The control arm bolts are pretty tight.
https://www.bronco6g.com/forum/thre...installation-on-base-bronco-diy-photos.69925/
The rear doesn't seem too difficult; my concern is how hard would the front one be
Valhalla
Valhalla
Chattanooga Tn
I thought I read they were bigger but I can't find it now. so don't take that as gospel.
Valhalla
Valhalla
Chattanooga Tn
With a lift it is not bad. It is one of those that comes right out, then you wrestle and wrestle to get it back. Then it magically pops in.
DGE1993
SGF-MO
'66 Mustang; '06 F-150; '22 Bronco
As someone who has had their front in and out three times now its not too bad. I have one of those cheap Harbor freight transmission jacks that you can ratchet up and down. it has a wider base that kinda snuggles up to the bottom of the diff nicely. The trick I have learned is when you start to lower it down you slide it over to the passenger side little by little until it is down. I have the 2.3 I4 so I cant really comment on the 2.7 V6 if there is any thing in the way that i don"t have.
Also the front drive shaft bolts are a "Torx Plus" (tp45 I think) a normal torx bit risk stripping them out. I got a cheap set on amazon for like $12. Glad I found that out before potentially having a trail fix situation and not having the right tools.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Awesome, thank you for your guys help!
