Ford Performance C-Brace install with hardtop
Robs94Bronco
Orange County
2023 Bronco Badlands Sasquatch 2.7L, 1994 Bronco Eddie Bauer 5.8L
No videos existed of anyone installing the C-Brace with the hardtop on...at least, I couldn't find one. Got one with the JOLLY25 coupon code.
It is very easy to install as it turns out. The overhead panels are pretty forgiving and unsnap easily.
Ford Bronco Ford Performance C-Brace install  with hardtop IMG_20260101_145436173_HDR
There's an online PDF with good instructions...just Google it.
Ford Bronco Ford Performance C-Brace install  with hardtop IMG_20260101_152136604_HDR
Your door tool kit has an "L" Torx that makes this install a snap.
Ford Bronco Ford Performance C-Brace install  with hardtop IMG_20260101_152347165_HDR
Ford Bronco Ford Performance C-Brace install  with hardtop IMG_20260101_152412307_HDR
Ford Bronco Ford Performance C-Brace install  with hardtop IMG_20260101_152905655_HDR
23OBX2.7
AB Canada
2023 Bronco
You want the B&C brace kit. Significantly reduces the massive body on frame torsional flex preacrically eliminating all creaks and rattles....very solid. lime one poster stated transforms from deiving like a dumpster to driving a $60K vehicle.
Should be standard equip and worth every penny.
wakblak
Curtis
Washington
Ford Bronco Badlands SAS, Genesis GV60
$500 is pretty pricey
Are there other options?
MDH
Southern California
2017 mazda6
This plus 1. The braces really work. One of my favorite mods.
Robs94Bronco
Robs94Bronco
Orange County
Besides... It looks bad A$$ when top is off and to be honest it's the 60% of my decision and of course the added rigidity.
Bronco Toad
Todd
Central Ohio
2022 Bronco Badlands 4dr Cyber Orange
My concern with the C brace is rear view visibility and making the back short from the floor up.
Ninjak
Miami
You still have plenty of room. On my Badlands, I had a B brace, of course, on the BRaptor I have both now. It does make a difference.
Pic below with an AAL M.A.S.S. unit installed. I also have a Ford Slide-out Tailgate. Plenty of room.
Ford Bronco Ford Performance C-Brace install  with hardtop 1767381572097-of
wakblak
Curtis
Washington
Anyone have a picture of what it looks like installed?
Bronco Toad
Todd
Central Ohio
Here you go... Barely noticeable..
Perfect thank you, that is exactly what I wondered. I have not seen the setup in real life. I have no basis just the angles I have seen and the way it looks in the picture online appears to make the back area appear "tight" and limit visibility. However from what you have it does not appear to impede like I had it in my head.
TimThib
Tim
Louisiana
2025 Badlands Sasquatch
Has anyone installed this on a 25 model? I know the 25 now has two dome lights on that panel and the kit would basically remove one of those lights? Just wondering if the 25 Raptor still has one dome light or two like the other models?
wakblak
Curtis
Washington
That's not too bad
