Ford Performance C-Brace install with hardtop
Mean Green
Bill
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
I’ve been price shopping for the B&C kit for a while. I might just break down and buy it as it does not appear to be coming down in price…
Robs94Bronco
Robs94Bronco
Rob
Orange County
2023 Bronco Badlands Sasquatch 2.7L, 1994 Bronco Eddie Bauer 5.8L
Waiting for the Ford 25% discount is an option.
Mean Green
Bill
Warminster, PA
It seems that even with the discount, many of the Ford distributors are cheaper in general. I thought about building up my points and the discount codes… End of the day, a few bucks is just my excuse for holding off a bit longer… if I ever found it in the $600 range, I would be wiping out the card on the spot! lol.
Robs94Bronco
Robs94Bronco
Rob
Orange County
It may eventually drop. I know that the tube doors where $2,500 when they first came out. Now they're $1,250. Which I'll be buying on the next discount run.
23OBX2.7
AB Canada
2023 Bronco
Wow there was a local guy with new set for CAD 500 that's USD350....
23OBX2.7
AB Canada
2023 Bronco
bellboyfab
So-cal
‘22Bronco ‘93 C3500
wyattburp
Oregon
2025 Bronco
Has anyone installed this on a 25 model? I know the 25 now has two dome lights on that panel and the kit would basically remove one of those lights? Just wondering if the 25 Raptor still has one dome light or two like the other models?
+1
I want the kit but have held off after hearing about fitment issues with the dome lights
F-Spot
SoCal
Tesla, FJ
I just installed the C-Bow brace on my ‘21 with the hardtop intact and without fully removing the side trim pieces. I pulled on the driver’s side intending to remove it, but it got hung up somewhere and the tabs were still partially engaged. I managed to pull it away enough for me to pull out the main crossbeam trim pieces on that side. I then loosely pulled on the passenger side trim piece and fully removed the center trim. The only issue I ran into was the side threaded insert on the driver’s side rear roll bar. I should have chased it but honestly it seems more like that threaded insert was installed at an angle which prevents me from getting a screw started. For now, that is the only anchor point that I don’t have bolted down.
Robs94Bronco
Robs94Bronco
Rob
Orange County
Hmmm... I had two screws that were very tight going in. Luckily, I have metric drill and tap set and I also chased those threads.
Techun
Pa
BD, 2.7, MIC, 4dr
You still have plenty of room. On my Badlands, I had a B brace, of course, on the BRaptor I have both now. It does make a difference.
Pic below with an AAL M.A.S.S. unit installed. I also have a Ford Slide-out Tailgate. Plenty of room.
I regularly use that space with some folding chairs that fit perfectly vertical there.
Not that it matters for me because I don't have those mounting holes :/
Motovita
WA/AZ
25 Bronco
The Ford website says "This does not fit your 2025 Bronco".
