Ford pass not showing current location
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
Picked up our Braptor last night and activated it on the ford pass app. When I select it in the app it has only shown the location when it was at the dealer and when it is at our house. When my wife goes anywhere it just keeps showing it at home and the message will say something like location last updated 48 minutes ago. Does this app require a wi-fi connection to be active on the braptor? What am I missing.
CarGuy
New Jersey
2023 Ford Bronco
Check the data sharing options in your setting in the truck to make sure you have the right ones enabled to offer up the location.
Taltyman
Taltyman
Paul
Forney tx
Ok, will do when she gets back. Thanks
userdude
Denton, TX
2023 2dr Badsquatch
That's one fast Braptor if it can move without being seen. 🤩
Karl_in_Chicago
Karl
Chicago
FWIW my (non-Braptor) MY23 BL, High, pretty consistently shows the *previous* position the vehicle was last parked and almost never the *current* position. So if I go out for a drive and the last place I stop is a neighborhood that is miles away that's what shows. Just looked at it now to check and it says it's parked at what would be Manny's Deli which is where I took my wife to lunch after her Dr. appt last Thursday - then we drove home. Now in my case my final parking is 3 floors underground in a high-rise building's garage so I understand why there's be no handshake but, at least IME, there doesn't appear to be any ongoing data refresh between the vehicle and Ford Pass. Just passing on a data point; for those of you NOT parking in underground bunkers I got nothin'. :)
Rydfree
Benny
Alabama
Swipe down on the Ford Pass app page and it will refresh its location and vehicle status.
Karl_in_Chicago
Karl
Chicago
Not here it doesn't. Just checked; the address shown is the last place I parked (across the street from Manny's) before coming home.
Ford Bronco Ford pass not showing current location 1700332041514
Rydfree
Benny
Alabama
The only time mine hasn't shown correctly is when it was in an area that I knew it did not have a good AT&T cell signal. Mine has worked correctly otherwise.
Taltyman
Taltyman
Paul
Forney tx
Played so more with mine last night. If I swipe down multiple times it will eventually refresh the location. Certainly doesn't work as good as life360 or find my friends that shows the location in real time. You would think when you open it that it would actually show the current location and not force a refresh.
