Fog Light switch location?
StarGazer
Tucson AZ
24 BRaptor
For a 2024 BRaptor, where is the fog light switch? I have two fog lights on each side of the front bumper, but have not located the switch to turn them ALL on… What am I missing? Thx
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Press the headlight switch IN. That's where your fog light switch is. That round dial... push it in.
The 2nd set of lights (which are identical fogs) is on upfitter 1.
StarGazer
StarGazer
Tucson AZ
24 BRaptor
THANK YOU very much. I felt like such a DipS__T even asking. Appreciate the info for sure. Maybe think about changing my deal to NEWBEE… LoL
BUFF
Mitch
SW Idaho
2025 F150 Tremor 402A
I believe for the fogs to work is first you need to take the light switch out of auto mode and into manual mode. Then push in the button in the middle.
helifino16
Ron
Mount Sinai, NY (Long Island)
Yeah, the factory default is also to turn off the Fog Lights OFF when the high beams are on. And like @BUFF said, the Factory default is to only be on when the headlights (low beam) are on.
I was able to go into ForScan to get the Fog lights to stay on as a DRL and when the High Beams ore on (Bambi Mode).
I believe that the ones on SW1 (Raptor unique) are unaffected by the Headlight switch (someone with a Raptor can verify?)
HeliPilot
Kenny
CT
2022 2.7L SAS
The fogs do indeed work in The Auto “Low Beam” mode. Expect a delay once the high beams turn off and low beams come on before the fogs illuminate. I didn’t like the delay, so I switched the fogs off and turned on upfitter 1. Those lights work anytime the car is in drive.
MGF
CA
Bronco Raptor, Merc AMG C63S, Range Rover Sport PHEV, BMW 328i
What Forscan line items did you change for Fog on with DRL and Fog on with High Beam - there’s a lot of fog settings in the Forscan table. In both cases do you still have a press the fog button for fogs to turn on? Thanks for input.
helifino16
Ron
As far as I remember - it was a long time ago - it was in the 'Plain Text' settings. Look here for a comprehensive spreadsheet (and discussion). The settings may have changed - or be different for the Raptor model. You can also search "Forscan spreadsheet' and find the settings.
Mine come on with the DRLs and stay on when the high beams are activated.
Hmm..
Not sure if it's any different for Raptor, but
Pushing the button enables the factory Fog lights on/off - but they will only turn on under the following conditions:
Turning the button -
Top position is OFF, I think only DRLs will work in this position (and maybe not even them, not sure)
Second position is Parking/Running Lights - and Fog will come on with Parking if they are On
Third position is Auto - and Fog will come on with Auto Low Beams and turn Off with High beams (either Auto or Manual)
Bottom position is Headlamps On - and just like Auto, Fogs will come on with Low Beams and off with High Beams
Should be a fog lamp indicator somewhere on the IPC - not sure where it would be on Raptor cluster. On my old Deluxe All-Speedometer model it's right next to the Auto Highbeam indicator.
For Fogs to stay on with High Beams - look for Bambi Mode info. And you still have to turn them ON with the button, but it has memory and will stay in the commanded location between starts.
Not sure how to get them on with DRLs - there is probably a Forscan command for it but I haven't tried it or looked for it.
JSW377
J
25 Bad Squatch
The ONLY stupid question is the one NOT asked! I too did not know this either…
