Floor heat non-existent?
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
So I checked mine out last night. I get tons of heat on the front floor (both sides), but almost zero airflow/heat in the rear seats (either side)
My BL is going in for the windshield warranty work at the end of January, will have them check out the HVAC then to see if this is what is expected.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this heated seat concern for you? Thank you!
2112
Fox island
F350 GT500’s FGT MACH I Z8
How do you know if the OTA 3.5.4 (Floor heat fix) has been successfully uploaded?
Ford Bronco Floor heat non-existent? 3982FD6E-9825-4C50-B717-202FFDDFBC18
tourproto
Portland, OR
Where did you read/hear that OTA 3.5.4 was a fix for this floor heat issue?
tourproto
Portland, OR
GeeDubya75
Galen
2022 Badlands Sasquatch and 2021 Explorer
Honestly I could dry my hair with the side window defrosters blowing 100mph ALL THE TIME. My feet freeze. Not happy. My heated steering wheel is a joke. MN winters are tough and this doesn’t make it easier.
have someone with a FORScan go in there and bump up the set temperature of your steering wheel.
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
Here in Detroit it has been 25-30 degrees during my first week of ownership. I’ll concede that the floor vents definitely aren’t moving large volumes of air. But I’ve been running mine on the “floor only” setting, warm air (half way between middle and max heat), and fan speed about a third of the way up. I gotta say it’s been plenty warm for my feet and I need to shed the shell layer of my jacket if I’m driving for more than 20 minutes or so. Looking forward to testing more when it gets down to single digits. But I’ve got room to increase the temp and fan speeds.
kristyb222
Kristy
Montana
2023 Wildtrak
Hi everyone, I'm new to this thread. I've had my 2023 Bronco for one week and the floor heat seems to be nonexistent. From this thread and another thread it isn't clear to me how/whether the floor heat issue is getting fixed. I live in Montana and drove for 45 minutes in -30 weather yesterday. My kid in the back seat had a winter coat and winter boots but his feet were numb by the time we arrived home. This truly is a safety issue for those of us who live in cold weather areas. I refuse to risk frostbite in my children inside a brand new car. So, what have people done that actually works? Desperately need a solution!
PrepVet
North Central WI
A bunch.
This weekend I had very wet and very cold summer rate boots. My poor tuttsies were very very very cold. I had it on floor and defrost and my feet were warmed up in about 20 mins or so.
TNBronc4344
JT
Kingsport
I’ve found that the only solution that Ford recommends is to move to Miami.
But seriously I live in a mild seasonal climate and it’s not my daily driver so it really doesn’t affect me that much but I feel for those who it really affects. Sorry guys. So many great things about the bronco and yet it does have a lot that needs improved.
Moto26
Tucson AZ
First thing is to take it to your dealer and tell them to fix the damn thing!
They know there's a problem, and they know some of the things to check, especially the ductwork that tends to be disconnected inside the center console area. That's the first thing they need to look at…
This is even a problem for those of us in the desert on cold mornings. I can't imagine what it's like to live in sub-freezing conditions with these problematic heating ducts... 🥶
The Beaz
Shad
San Francisco
See post #179 above...Have your dealer check the temperature sensor, that is what seems to have solved it for me.
2112
Fox island
https://www.bronco6g.com/forum/threads/cold-feet-floor-heat.31841/page-3#post-1318400
Post #34 on this thread offers a solution. Haven't had a chance to try it yet, if you do, please post back.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Well here in FL and NC last week in only 20* weather floor was too hot. All good here. Must be a hit or miss with the Bronc
