Flat Towing, unexpected brake lockup.
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
So was the problem active brake boost making the auxiliary brake system too active or did the Bronco apply brakes independantly?
There auxiliary system is adjusted for no boost, if boost activates the auxiliary system applies pedal too far due to lack of resistance of the brake pedal so the first one.
sfearnow
austin, tx
Details:
2022 Ford Bronco Outer Banks Sasquatch 2.7
Flat Towed with professionally installed air brakes. (Demco Air Force One with Blue Ox tow setup)
Just had my parking brake engage while flat-towing yesterday. On my return trip, second day of travel and had not been in or touched the Bronco at all.
180 miles into the day, we stopped for 20-30 minutes with RV engine still running, but parked.
Pulled out of the rest area in Shepherdsville, KY and saw a cloud of smoke behind me. Pulled over and saw long rubber tire trails all behind me. Both rear Sasquatch tires flat as can be from being dragged.
When I got in to disconnect flat-towing and disconnect so the tow truck could load, there were no errors on dash, still properly in flat towing mode and gear still in Neutral. The only thing of note was a red PARK indicator on.
This was not manually engaged, and took me a while to find where to disengage it as we live in a flat suburb of Austin, TX.
Had roadside assistance tow me to a tire shop—which of course doesn’t have the stock Goodyear Sasquatch tires that are on the rest of the Bronco. Will go mismatched from here and rotate old to rear.
Now in the unenviable position of not being near a Ford dealer—with family and dogs still a three-day drive from home.
Trying to decide whether to unplug the power to the rear brakes on the Bronco (tire tech recommendation) and rely on front only plus RV brakes to continue or try to find the rear e-brake/parking brake relay.
Thankful to find these threads as the only other solution I could fathom was someone nefariously engaging the brake at the Rest Stop. Really not a reasonable conclusion, but at my wits-end as it has been working flawlessly until
.it wasn’t. Now one day behind in travel and out the cost of two tires (so far), plus a tow. Will have to consider whether to upgrade to remaining three tires to match when I get home—so cost will exceed $2,300 even if it doesn’t fail again on my way back to the Austin metro.
Ford Bronco Flat Towing, unexpected brake lockup. IMG_5761
Ford Bronco Flat Towing, unexpected brake lockup. IMG_2682
Ford Bronco Flat Towing, unexpected brake lockup. IMG_5758
Ford Bronco Flat Towing, unexpected brake lockup. IMG_2680
Ford Bronco Flat Towing, unexpected brake lockup. IMG_2681
Ford Bronco Flat Towing, unexpected brake lockup. IMG_5763
Ford Bronco Flat Towing, unexpected brake lockup. IMG_2962
dgorsett
colorado
F250, Mustang, Explorer
There should be a fuse to pull to disable parking brake or unhook wires at actuators at calipers . This would disable only parking brake and not service brakes. But might send a code to the Bronco causing a freak out.
I had brakes set (never new if service or parking) inexplicably off road once, never has happened again.
BTW I never use the parking brake during the flat tow set up process or while flat towing nor do I let anyone help me set up (anymore). A friend helped with my old Wrangler once and set the brake, not as bad as your result but anyway...
Bsenecal
Vermont
'19 Ranger crew cab, '17 Fusion sport, '68 Mustang
Details:
Good luck with everything. Bummer about the parking brake coming on.
BTW, nice coach.
Fordified1
Bob
Mid South Texas
Details:
supposedly the flat tow procedure from Ford has been updated with the added need to pull two fuses related to the brakes. I was thinking it was mentioned in this thread somewhere. I did not go back and look.. If not here it’s in another. Make sure you have the latest version of the Bronco flat tow procedure.
Also my rear monitor has a microphone and I always turn up the volume when I first set out on my way to make sure I don’t hear any strange sounds. It actually saved my Jeep gladiator tires as the parking brake locked up on it one time. That rear microphone also clued me in that a safety chain had come loose and dragging while towing a trailer.
grtharris
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
The parking brakes are controlled by the ANATI-LOCK BRAKE SYSTEM (ABS) MODULE. The fuses that power that module are F28 60A and F29 60A which are the ones Fords said to pull when flat towing.
By the way my bronco is at the Ford dealer, my extended warranty is about to end and I have a small oil leak around the right side of the rear axle, so I took it in to get as many of the recalls done as possible. I also added the brake issue of the EBB randomly coming on when flat towing.
Going to send the service writer a link to this thread.
psdtime
Tom
CA
2026 Bronco
Also, there is more than just pulling the fuses. You need to open the hood, close all doors, wait 5 minutes, then pull 29 and 28 (in that order). To replaced. Do everything the same(hood, doors, 5 min wait) except you'll be replacing the fuses instead of removing, but also in order of 29 first. The 5 min wait is to allow the Bronco to go in sleep mode or something like that. I haven't flat towed yet, but I have set it up and I'm ready for the first tow.
Tilzbow
NV
GM Sierra Diesel Pick Up
I just checked. The manuals for model years 2025 and later have been updated and include fuse pulling. Model years 2024 and earlier don’t include fuse pulling. I have no idea why it’s different for earlier and later model years.
psdtime
Tom
CA
2026 Bronco
If I remember correctly is has to do with a different type of brake booster or something like that. There is a lot of info here. https://www.bronco6g.com/forum/threads/flat-tow-equipment-needed-to-flat-tow-the-2021-bronco.19759/ .
sfearnow
austin, tx
Still a few days of towing left on this trip. Will try pulling the two fuses and report back here. Took the Bronco to an unnamed Ford Dealer in Louisville today but they could not commit o
Well, my 2022 sure threw a lot of errors and warnings with just pulling the fuses and would not allow me to enter Flat Towing mode. Will be very interested to retry sometime with your steps above.
psdtime
Tom
CA
2026 Bronco
This info is from the 2026 model year owners manual. Check your manual for updates on the Ford site and follow those recommendations.
grtharris
grtharris
Grant
Skiatook, OK
As per manual remove fuses 5 min after enabling TOW mode and install them before disabling TOW mode and there is a specific order to pull and install the fuses.
Valhalla
Valhalla
Chattanooga Tn
Details:
I have 5 of those tires you can have for 20$ a pop. Just in chattanooga so shipping would cost.
Fordified1
Bob
Mid South Texas
Edit: thought I posted this earlier. I don’t know about the V6 models because they had electric brake boosters all along but in 2025 the four-cylinder got an electric brake booster also and they were vacuum before.
Tilzbow
NV
Since that’s the case it wouldn’t surprise me if Ford started using a new EBB that’s common to both the V6 and 4 cylinder at that time, the engine previous software wasn’t capable of turning it off when going into flat tow mode and thus the need to pull fuses from 2025 on.
