wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
I've only flat-tow'd a manual Civic behind a MH, no issues but the Civic was light and barely noticeable. But, read recently about a Wrangler owner who had a No Start after towing his new, manual Jeep some distance. Turns out he had the transmission in gear instead of Neutral and had inadvertently put the Transfer Case in 4L instead of Neutral. The Pentastar was turning huge RPM while being pulled and destroyed itself from the inside out. An expensive mistake.
PA BRaptor
Kevin
Western PA
Ford F350
Had a friend who did something similar. Hooked a Ford Ranger to a pusher and pulled it from PA to FL. Left the Ranger in 1st gear.
broncobase1
Lincoln
22 Bronco Base
Carnage.
I still think flat towing a Bronco is a bad idea.
Buy a Wrangler with a manual transfer case instead.
What's the reasoning behind that comment? The Bronco is designed to be flat towed. This accident had nothing to do with the Bronco's ability to be flat towed.
broncobase1
Lincoln
22 Bronco Base
Pentastars are good engines, they don't destroy themselves from running high RPM. Of course if you redline for hundreds of miles that is crazy stupid. What was the driver thinking?
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
Have you not seen the amount of threads here with people grenading transmissions and transfer cases flat towing?
Then Ford denying warranties?
vrtical
Doug AI
GSMNP, TN
Fords
that may be true, but having an electronically controlled transfer case is no go. Hence the recommendation to get a vehicle that has 4x4 also have a manual transfer case engagement.
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
Fordpass will alert for low tire pressure, it's a free way to monitor.
I don't think it would do that when flat towing. Note that the vehicle is off while flat tow is engaged, but I'm not sure.
broncobase1
Lincoln
22 Bronco Base
Unless you have the Advanced 4x4 option, the so called electronic control is nothing more than an actuator motor for shifting (2H, 4H, 4L). It's not going to affect flat towing in any way, its just a plane jane transfer case when you're not shifting. The Advanced 4X4 of course is a different animal, but even with it I'm pretty sure when in flat towing mode its neutral and all the electronic stuff is inactive. I have driven Jeeps and I really appreciate the Bronco electric shifting. It seems to be a chore to shift a Jeep, takes a lot of muscle. That said, I'll pass on the extra complexity of Advanced 4x4.
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
Clueless comes to mind.
grayshadow
Charles
Humble, Texas
So Ford should warranty something due to the inability of the owner to follow the owners manual? 🤷‍♂️
I have flat towed mine almost 20,000 miles so far.
noliveaxle
john
Riverside, Calif
2015 jku rubicon
I have seen two wranglers that locked up and destroyed tires.
Operator error. No way that’s caused from hiccups from computer. Very hard to make a mistake. Put into park(gear) set transfer case to neutral. Haha release parking brake. I forgot the last part. Got me some purple/blue rotors.
