Flat Towing a 2024 Wildtrak
Larry Tague
Larry
Reno, NV
2024 Wildtrak
How many are flat towing their Bronco with the Mod. Bumper and stock Performance D-Rings. Is this a long term safe method?
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
I would consider one of the frame horn reinforcement kits and a high rated tow bar. Along with a good braking and breakaway system. These are very heavy with allot of twisting forces from the tow vehicle. Picture the tail wag effect steering down the road and corning. Keep your tow bar as flat as possible.
Larry Tague
Larry
Reno, NV
2024 Wildtrak
Thanks, I have been flat towing my jeep for the last 32 years. I do use a loadmaster tow bar, a brake buddy, and do keep it as level as possible. Just curious about using the performance d-rings how that I have switched to a bronco. I did order the frame horn kit.
lamokadave
I'm probably approaching 10k miles of flat towing my 24 Bad Lands SAS using the D rings. I did install the LOD bumper reinforcement brackets. I also use an auxiliary braking system and a Roadmaster all-terrain tow bar. I did need to purchase the adapters for the Roadmaster tow bar to attach to the d-ring.
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
I use the modular bumper stock recovery hooks and have had no issues.
goatman
Richard
Bakersfield
'22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
I have 30k miles on the Bronco, '22 Badlands, with extensive flat towing with no issues. I use the D ring tabs on the bumper. I also have an Air Force One brake system.
KWalker
Kevin
Illinois
2024 Bronco Wildtrak, 2021Tiffin Allegro Red 38LL
Did you add the frame horn reinforcement kit before towing?
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
I flat tow my outer banks and also use the bumper ”D” ring tabs , without reinforcement. Pulling a Bronco out of a mud hole is a lot harder pull than what it takes flat towing, Once it’s moving there is little load.
Larry Tague
Larry
Reno, NV
2024 Wildtrak
1 I
Do you have to pull the 60amp fuses if using an aux. braking system on a 2024 with 2.7 auto. The first time I flat towed, the brakes locked up with the fuses installed. The flat towed instructions do not mention having to pull them.
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
The Bronco is not a vacuum system it’s an electronic booster so when setting up the brake system do not choose vacuum booster. I use the setting for panic braking only and do not have any issues, There has been a lot of discussion on this topic, I have the RVI 3 brake and I’m still fine tuning for what works best.
Larry Tague
Larry
Reno, NV
2024 Wildtrak
I
Thanks, I have the brake buddy and will have to play with it. I thought I read that they disable the electronic booster when it’s in the flat tow mode.
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
Yes it is supposed to to be disabled but still if your setup ask if you have a vacuum system it makes a difference, that’s all I have sen others with the RVI set it up for the vacuum System, kinda confusing they need to explain it better so people understand the difference in how it works
dgorsett
colorado
F250, Mustang, Explorer
Broncos with the 2.3 up until last year are vacuum, so follow the vacuum procedure on those.
