2024 Wildtrak Changes
ohp138
Gary
2024 Wildtrak and 2022 Outerbanks
We currently own a 2022 OBX and recently received our 2024 Wildtrak. Two things that have changed that I haven’t seen discussed yet:
1. Top Bolts for rear roof (roll bar). There are now two bolts per side rather than just one. If you plan to add Rockworx bolts, just know you’ll need four of the flat bolts for the top.
2. Temperature Reading on dials. Our OBX has dummy knobs and the temp adjustment reading is only on the screen. I believe the 2021 models had the adjustment reading on the knob and Ford removed it for the 2022 year. It’s definitely back for the 2024.
Ford Bronco 2024 Wildtrak Changes IMG_0971
Ford Bronco 2024 Wildtrak Changes IMG_0972
Ford Bronco 2024 Wildtrak Changes IMG_0969
ohp138
Gary
Mjasi3
Chicago
And 24 WT come with plastic rear bumper, not metal.
Sp8Ball
MD
2022 Bronco Wildtrak; 2017 F150 Platinum
Is it possible put temp dial knobs on a ‘22? Or is a different control/interface unit (or software) needed, as well, making it impossible?
DemonGT
Dan
Wisconsin
2022 Badlands
What is the purpose of the rock worx screws?
Ninjak
Miami
Replacement bolts for the hard top, also allow you to do tie-downs to them. Will not need a Torx tool to take them off.
Ducati1098
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
I love mine. I use them all the time as tie downs for my cargo.
Ford Bronco 2024 Wildtrak Changes PXL_20240628_161632155
