Flat Tow 2024 Wildtrak
realtorbrad
Brad McKissack
Argyle Tx
2024 Bronco
Purchased Bronco over Jeep to flat tow behind my MoHo, Do not need to purchase new baseplate to connect to roadmaster tow bar.
Fordified1
Bob
Mid South Texas
Is this a statement or a question?
If this is a statement, you must have the modular bumper. Otherwise explain please for benefit of the forum.
realtorbrad
Brad McKissack
Argyle Tx
2024 Bronco
Purchased Bronco over Jeep to flat tow behind my MoHo, Do i need to purchase new baseplate to connect to roadmaster tow bar?
Fordified1
Bob
Mid South Texas
It depends on what bumper you have. You may just need adapters to pin to your recovery hooks. Or change your current recovery hooks to the style most aftermarket have. Or buy base plates, but they are pricey.
There are multiple threads on this forum that discuss options.
I simply bought adapters to adapt my Blue Ox tow bar to my aftermarket bumper. I think they were $60
Ford Bronco Flat Tow 2024 Wildtrak IMG_1470
Fordified1
Bob
Mid South Texas
You really need to put “Flat Tow” in the search (titles only) and read up on issues and setups. It may scare you into not wanting to flat tow it. Or it will at least prompt you to document every time you put it in neutral tow so you have ammunition in case you have a transmission issue and need to get it warrantied.
realtorbrad
Brad McKissack
Argyle Tx
2024 Bronco
I have seen some of the posts on flat towing and many are scary. I flat towed my jeep previously without any issues and have been flat towing my F250 for 3 years no issues but wondering if I made a mistake buying Bronco with some of threads I read.
Fordified1
Bob
Mid South Texas
Dez Pony
Rick
Descanso
'97 Jeep TJ, '19 Ranger
You don't need a Baseplate if you have the modular bumper. Mine is a Badlands. I use a Roadmaster Falcon 2 tow bar and the Demco Stay 'N Play Duo auxiliary brakes. Depending on the receiver height on the motorhome and the level of the front hookups on the Bronco, get the riser to get the tow bar level as possible.
Ford Bronco Flat Tow 2024 Wildtrak IMG_1096
