Fire extinguisher recommendations? Rear mounted options?
JaxGtc
I did the Element with magnetic mounts. Paint protection film used. Magnets are super strong.
Ford Bronco Fire extinguisher recommendations? Rear mounted options? Element
HalfmuleFarmer
Thomas
2025 Badlands
Some groups require it. I agree, it serves no useful purpose. Not big enough to put out a real engine fire. The chances of needing one are probably less than 1:10,000
I’m the 1:10,000 case. Had a highway engine fire in a Land Rover. Had a slim Halotron extinguisher. Popped the latch and emptied in under the hood. Did nothing. Fire Dept showed up in about 5 minutes and foamed it out. Total loss.
PS: I still carry an extinguisher in the Bronco. I figure maybe useful for campfires or in the garage.
rbalazs
Ryan
Snohomish Wa
2024 f350 HO Tremor, 2023 Bronco Badlands Sasquatch
Well, I installed one in the bronco and my F350 because we own a construction company and these are my vehicles I checked jobs with and our safety manual says we need them in our vehicles.
HalfmuleFarmer
Thomas
2025 Badlands
Oh I think it’s a fine idea to carry an extinguisher. Like I said, I still do. Doesn’t take up much space. Thinking a 2.5 lb unit is going to put out an engine fire? That’s a triumph of effective marketing.
rbalazs
Ryan
Snohomish Wa
True, but if someone’s stuck in a car and there’s a fire, it might give enough time to get them out. A lot of the things that I end up doing or carrying is to have the possibility of helping someone else.
Pbethel
Patrick
Kingman AZ
2025 Bronco Sasquatch, 2016 Transit 250 148 MR EB
New here. Using the search engine looking for fire ext mount ideas and see people questioning if it is even worth it. My fire extinguisher held the engine fire at bay long enough for bystanders to extricate 2 victims from a Yj involved in a head on collision.
Rescuers were running down the line of stopped cars looking for more because they had allready used 2 and the fire was beginning to flare up again.
No, 2 1/2lbs didn't stop the fire but suppressed it just long enough. The whole jeep was a ball of flame 30-40 seconds after the extraction and before they found another and could get back with it.
Any good suggestions for mounts and location?
Oldhippie
Barry
Santa Cruz, Calif.
Mostly to keep inspectors happy…cheap eBay mount to keep it from flying around…never had to use one for real (safety classes only)…
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_0509
Pbethel
Patrick
Kingman AZ
To those that bemoan the ineffectiveness of the 2 1/2 lb ext. but the group they wheel with requires it.... you won't all catch fire at once. Ten of you? 25 lbs.
I have experienced vehicle and boat fires that got put out with A 2.5 lb.
But if the opportunity presents itself participate in some training. It helps.
