Fair Pricing for a 2 inch Zone Leveling Kit
ct_bronco73
Lance
CT
2023 Ford Bronco Badlands
I was quoted $1450 for installing a 2 inch Zone leveling kit:
https://zoneoffroad.com/products/2-...quipped-21-26-ce83b20e?variant=42278354649176
On Zone's website it stated that labor should be 2-3 hours but I was given $840 for the labor. 4 hours just for the front and about 2 hours for the rear.
Is this reasonable? From my research it appears to be front should be easier than 4 hours to do for a shop.
Any inputs would be appreciated. Thank you!
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
I did mine in about 4 hours with a friend and my 2 post lift
ct_bronco73
ct_bronco73
Lance
CT
Thanks. I figured 6 hours are on high side for a 4x4 shop.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I would look at Bilstein 5100s so you don't pay twice down the road when you need new shocks in 1-2 years.
$500-600 for install and $100 for an alignment. Its maybe 3 hours for skill mechanic, even less with good power tools.
BroncoAdventure
Alabama
'24 Bronco 4 Door
This ^^^^ best advice. I originally installed a 2" spacer lift, then a year later installed Bilstein 5100s. I ended up just leaving in the spacers when I installed 5100s, in which I also included a trackbar relocation, diff drop bracket and upper control arms. I did the installs myself...I'm by no means a mechanic but understand how things work and have the proper tools....and youtube!
KillerPenz
North East
As @swami37 stated, it's about a 3-4 hour job, definitely helps if it's a 2-man job. Rears are easy. The front is the issue as you are dealing with the cv axle. Otherwise, not too bad. Definitely better than paying $1450!
CelticCactus
Michelle
texas
bronco
which ones did you go with, if you don't mind my asking? I'm thinking about this so I can move into 35s. are you happy with the difference?
ct_bronco73
ct_bronco73
Lance
CT
Thanks everyone for your feedbacks. I'm leaning towards having Bilstein 5100s when OE shocks wear out.
