Factory SAS wheels and 1.25" spacers
meffie
Raven
'23 WildTrak
Hello folks. Sorry if its been asked, but hunting through threads trying to find this specific question is becoming a bit tedious.
With a 1.25" spacer and factory SAS wheels in mind, do the wheel studs need to be trimmed to clear the back of the wheel? I know there is no issues on 1.5", but Im trying to get as close to 0 offset as possible, so 1.25 should be the sweet spot.
Thank you
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Thank you
I currently run hub centric wheel spacers that are 1.25” on factory Sasquatch wheels. Fits fine. 0 offset and 1.25 are practically identical.
Before the spacer police join the chat, I’ll add a few remarks about my experience with wheel spacers. I’m running mine as a band aid until I decide on wheels as I need clearance for my aftermarket suspension. I drove 2k on my wheel spacers and did 4 days straight of hard off-roading in Moab with jumps, whoops at 55mph and lots of 6/10 trail running. The spacers did ok. That being said, even with loctite and a retorque they had started to come loose. So be careful and check them often. Personal recommendation is to switch to 0 offset wheels when able. But until then run spacers and just maintain them.
PWillette
Parrie
Maine
I have 1" spacers on my non-SAS w/o issue. I'm not 100% sure but I do believe the SAS wheels have the same void on the back side as the non-SAS wheels, you should be good.
meffie
meffie
Raven
'23 WildTrak
Sweet, exactly what I needed to know, ty.
And PS: Not worried about the spacer police. Half of them have no conception that the bearing load is equal with offset, not how you get to said offset. A true 0 offset wheel provides as much additional load as a spacer that gets you to 0. That being said, yea sure you could say it's an additional point of failure, but again, really not much difference from properly checking/re-torquing a wheel. meh.
NORCALGXP
Sacramento, California
2017 Raptor
LIONDOG
SE Michigan
2022 Bronco Badlands SAS MT
1” spacers on my SAS with no trimming.
MNBigfoot
MN
Before the spacer police join the chat........I’m running mine as a band aid until I decide on wheels as I need clearance for my aftermarket suspension. ......... Personal recommendation is to switch to 0 offset wheels when able. But until then run spacers and just maintain them.
Spacer Police has entered the chat.
