Factory Fog Light Switch
ModifyMike
ModifyMike
Ford F450
I have the Lux, and so I chose the DA switch because I was only looking for the single controller (not also the rear fog).
Yup this is correct, I wanted the ability to control a rear fog which is why I chose this switch.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
OBX with Modular front bumper with Tow package. Have looked a couple of times at the rear bumper and do not see the rear fog light connector. Drawing shows it dropping off the wires going to the sensor next to the tag light.
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
I ordered the switch for front/ rear fogs last. right from "Online FordPartsCatelog.com"
They canceled my order this morning and stated they would be refunding my money ........Stated reason : Due to "Nationwide Backorder"
WuNgUn
Ontario Canada
2 door Squatched
Damn... I hope they go back into production with the double fog switch! 😩
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
ModifyMike
ModifyMike
Ford F450
I figured they would catch up with inventory over time, ordered mine from a local dealer and at that time there was only like 5 in the warehouse.
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
Oh this is fantastic. Once an affordable modular bumper light bracket is out I'll get some fogs installed.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I may have one available if the wiring isn’t at the module above the fender. I’ll check when I install the block heater.
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
Mine came today, but it is the wrong one.
geoking
george
Huntsville,AL
Pls pm me if it becomes available?
Bee Bop
Shane
Temple GA
The switch issue is solved. I ordered the Switch ML3Z-11654-DA
Ford Bronco Factory Fog Light Switch IMG_0852
everything was correct except for the mirror light buttons were not there, I had these buttons instead.
Ford Bronco Factory Fog Light Switch IMG_0849
I was reading in this Thread about how they are on back order now and was stating to get P.O.ed that I had the wrong switch, but then I got to looking at the switch to see if there was anyway I could some how make it work. That Is when I noticed that the left buttons were a separate module that pluged in to the main switch. So I started taking the face plate off and was able to remove the buttons. i then replaced them with the buttons from my old switch.
Ford Bronco Factory Fog Light Switch IMG_0851
Ford Bronco Factory Fog Light Switch IMG_0850
Volia I now have a functioning switch with the foglight button and the correct lamp buttons.
Ford Bronco Factory Fog Light Switch IMG_0848
I tested the functions and everything is working properly. All that is left to do is activate the foglight button once my BD light kit comes in.
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I’m curious about you ordering ML3Z-11654-DA …I had taken down the switch part number as M2DZ-11654-DA. Glad you made it work!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hey @4x4TruckLEDs.com - so here are the answers for the awesome setup to save an upfitter!
Yeah so I honestly forgot all about this thread but someone asked about this recently and I decided to take a look. I'm reading through all the posts and I plan to grab one of the M2DZ-11654-DA myself.
What Im still reading/trying to find is a pig-tail that you could use to plug into the factory connector with 2 wire leads that you could then splice onto OUR upfitter harness.
dcg2
Don
PA
Honda CR-V
Apparently these are them:
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/post-951147
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
I read through this entire thread but it was a little bit unclear. Where is the wiring for the modular bumper on vehicles with lux package located? And are people using connectors to tie in aftermarket lights with the factory wiring?
