Factory Fog Light Switch
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
ModifyMike
ModifyMike
Ford F450
This reminded me I wanted to check for this. I did some peaking and didn't see it so I went and looked at wiring info. It doesn't exist unfortunately. However it's not completely non-existent. The harness it would be included in is actually for the license plate light. The connector (attached below) is pre wired for the rear fog on the body (female) side. So if you do want to use this as a source for some rear lights you would just need to land a wire into pin 3 on the bumper (male) side of that connector, enable rear fog in FORScan and voila you have an easily toggled rear lighting solution.
I wish I would have dug into this sooner for those who were eager enough to actually buy the rear fogs. The idea definitely isn't dead but it is just a little bit of extra work than anticipated. Honestly though I feel like this is still a relatively easy way of adding light power since you don't have to do wiring all the way back to a power source under the hood/use the upfitter provisions. Hope this helps someone and I hope to see something come of this finally. With this discovery I myself am kind of intrigued to go through this process. I don't have any rush to add rear lights but it's crossed my mind for an option in the future.
Thank you for this!
etmccaus86
Evan
Motor City
'22 BaseSquatch
Just an update from a Black Diamond - that wire/harness is NOT in the front bumper. So, likely everyone with a 2022 will be better off…as of now it looks like the wiring is at the switch and potentially goes to C203. From there - we’ll have to see. Thanks to @flip for helping me sort this out. Bummed it’s not going to be as easy as I hoped to upgrade the headlight switch and save an AUX.
Stinks, but that's workable. Anyone know a p/n for a terminated lead for this that I can then splice into a homemade fog harness?
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
I wish I would have dug into this sooner for those who were eager enough to actually buy the rear fog switch, the idea definitely isn't dead but it is just a little bit of extra work than anticipated. Honestly though I feel like this is still a relatively easy way of adding light power since you don't have to do wiring all the way back to a power source under the hood/use the upfitter provisions. Hope this helps someone and I hope to see something come of this finally. With this discovery I myself am kind of intrigued to go through this process. I don't have any rush to add rear lights but it's crossed my mind for an option in the future.
Wow! , you’re awesome! My Bronco is currently scheduled for build “week of Jan 3. “ When it get’s here , I’ll make up the third conductor for the male side to add it for an “upgraded “ rear light feature. I’ll probably use it for a rear SS1 Clear lens fog with red LED back light . Is the running light pin ieither pin 2 or pin 5 by any chance. It will save me looking manually. Smile
My add on harness will need 2 conductors plus a ground . Thanks for making this very doable . While the switch assembly is still on back order, it will eventually fill. While I wait, I’m trying to work around it by utilizing @BeeBops accidentally getting an incorrect version.
I have ordered the wrong dual fog deliberately to see if I can utilize it. IE modify to utilize parts from both.
…..will advise as I do not have an ETA.
I’ll call the parts folks today to see IF it was in stock?
Thank you again!!!!!! 🎂 appreciate it!
WuNgUn
Ontario Canada
2 door Squatched
Alfie,
The fog light indicator is on your instrument panel and the images on the switch do NOT illuminate ,
Regards,
George
I assume you mean the switch doesn't change illumination to show its on? I'm going to also assume it's backlit like all the other interior buttons...?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’m in the same boat.
C203. I highlighted the two cavities the wires should be in.
Ford Bronco Factory Fog Light Switch 59FB5DD3-3432-406C-8896-1C75761EDC18
Thanks to @flip
Alfie623
Alfie
Newburgh, NY
1983 Bronco
Correct, the switch face doesn’t illuminate when it’s on and the switch isn’t backlit
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
@D2dhanover where are you getting all the wiring diagrams? Do you have a service subscription? Helm hasn't released the wiring manual yet, they state it will be available 12/31/21
geoking
george
Huntsville,AL
I can't find any part numbers for this, the info actually says there's no pigtail kit available.
Yes it's Fords service system.
No issue... does the system show the tag light as an assembly? I could order it now to see what the connector is? this would enable me to share with everyone.
redone17
Cold Spring, NY
Yellow/Orange and Brown are under the steering column, but C192 is NOT under the headlight…
Side note: there was a bunch of SAND under the steering column from visits to the beach over the summer. Presumably from tire kicking it up? 😬
BroncoAZ
Mitch
I just ordered the M2DZ-11654-DA switch for my Badlands High. The price has gone up a little, $72.77 was the cheapest I could find from Tasca, so $89 with tax and shipping.
I bought the Forscan adapter on Amazon for $39.
geoking
george
Huntsville,AL
Please let us know if you are able to get it shipped as they may not be able to get the switch for a while .
