Factory Fog Light Switch
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
This is pretty awesome! thread is bookmarked.
Can someone explain to me: The pocket fog lights seem to come with three pairs of lights, and those sets have differing use cases, does only one of the three get tied into the OEM fog switch and then upfitter controls the other ones for other use cases?
rdg698
Gil
South Carolina
Ford F-150
I think the bigger lights on the inside get tied to fog lights. The other lights are brighter driving lights that can be connected to aux switches. That’s my plan.
Merc4x4
steve
NJ
I would only tie SAE designated lights to the factory switch (for other people driving your car that might not be aware and accidentally turn on blinding off road lights).
There is also a maximum current rating for the factory harness. I don't know what it is, but 6 LEDs are probably too much.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
You have the choice as to what you connect. I did what @Merc4x4 suggested - put my SAE Amber fogs on the factory switch as I wanted them to act like factory lights (no bambi mode) and not take up an upfitter. The wiring is there for whatever you connect to it (within the noted limits)
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
mds5917
New Jersey
TRMFAM
Rob
OK
Found this too by searching this site with the part number.
I am clearly missing it but what is the difference between BA and CA?
I have an FE and would like both front and rear fog switch...Pretty sure CA is what I need but the chart above I can't tell the difference.
I think it would be great to add the backlight on the aftermarket lights to the rear fog switch...
Some assumptions here: If the rear fog is on then activates when headlamps turn on...seems like a sound guess. If that is the case will be perfect for my plans...right now on the Raptor I have all the backlights on one upfitter and manually turn on / off depending on darkness outside. Would be great for that to be tied to the headlights and free up another upfitter.
mds5917
New Jersey
do you have a package with puddle lamps? That makes the diff whether you are AA/BA vs CA/DA
TRMFAM
Rob
OK
Yes it is Lux package...and you are right, I now see CA says puddle. Grrr...like looking at one of those where's Waldo books! Thank you for the smack to the head!
mds5917
New Jersey
I have the Lux, and so I chose the DA switch because I was only looking for the single controller (not also the rear fog).
ModifyMike
ModifyMike
Ford F450
$195?!?! Should be $50-60
Sorry I paid 70 bucks, the freight was for the whole order for my shop including a bunch of super duty parts.
