Factory Fog Light Switch
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
Awesome - got my connector today and made the changes and now my fogs work perfectly from my replaced switch on my badlands with BD lights! Thanks to all! Now to kill that double honk…
mds5917
New Jersey
Of the lights, or the install process? I did not have any pics that had not already been published for installation, aside from perhaps where I ran the harness, and I have posted a pic of the switch replacement, which I am happy to post again. The FORScan stuff was covered here and it worked. I did use the extra male weathershield connectors that @4x4TruckLEDs.com to replace the factory connectors that were terminated in my MOD bumper so I could use the new switch and not an upfitter. All I have left to do is aim the lights properly - one of them is searching for aircraft, as best I can tell :p
Ford Bronco Factory Fog Light Switch Bronco w BD Lights
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
What connector did you use?
mds5917
New Jersey
gizmohd
Darren
mds5917
New Jersey
Sorry.. I was talking about the connector used to connect to the factory fog light wiring harness.
I removed (cut off) the factory connector and replaced it with a male weathershield connector that mated to the female connector on the harness 4x4truckleds provided
gizmohd
Darren
Yea.. I think instead of hacking into the factory wiring. going to try this 10$ option first.. :)
Ford Bronco Factory Fog Light Switch 1636256830798
dcg2
Don
PA
Honda CR-V
Ok. The slow kid is confused again.
I thought the existing wired up connectors on the Bronco are female connectors and IF one did not want to alter the factory wiring, one would have to make the wiring from the fogs have a male end.
One could do so either by reusing the weather plugs (with alteration) that exist to seal off the harness connectors
Or by buying some of the correct male connectors with pigtails.
WuNgUn
Ontario Canada
2 door Squatched
Are you also doing the rear fog?
Has anyone checked that the rear harness is also there?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
That’s what I thought too.
Exciting that the Forscan transition was a breeze.
For the Black Diamond folks… @flip was nice enough to share this diagram of C203 (which should be sitting behind the fender wall under the battery). We’re looking to see if the highlighted pins are wired from the switch.
Ford Bronco Factory Fog Light Switch EADD8CE5-E3A6-4C44-8E70-48E1B7E2303D
mds5917
New Jersey
I am not doing those, but someone published a schematic that show there should be a plug (at least on some models) there for it. I may do "work/reverse (trail) lights" in the spare and run them from the upfitter via the rear upfitter wiring, if I do not use that for on-board air if I ever see anyone bring out a good mounting option.
mds5917
New Jersey
I used the male one shown here to replace the female one that was on the Bronco under the tow hook. This fit the female (shown here) that was already on the harness I got from @4x4TruckLEDs.com for my upfitter kit for the Baja Design lights. I soldered the Bronco wiring to the pins (as well as crimped) for a little extra comfort, as well.
Ford Bronco Factory Fog Light Switch 1636289454939
mds5917
New Jersey
