Factory Fog Light Switch
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Just an update from a Black Diamond - that wire/harness is NOT in the front bumper. So, likely everyone with a 2022 will be better off…as of now it looks like the wiring is at the switch and potentially goes to C203. From there - we’ll have to see. Thanks to @flip for helping me sort this out. Bummed it’s not going to be as easy as I hoped to upgrade the headlight switch and save an AUX.
Ford Bronco Factory Fog Light Switch 831EF242-AB89-4C46-A7BB-6CE1FFA6A2BF
Ford Bronco Factory Fog Light Switch CD0D21CB-098A-404D-B92D-CDDC64D00FFC
Ford Bronco Factory Fog Light Switch B8761181-ADBE-45C9-BD2B-9FC565007E9E
redone17
Cold Spring, NY
does anyone have the part number for the switch with fog and the mirror lights?
They’re listed earlier in this thread.
dweskamp
Dan
Missouri
2016 GMC truck
nobody's forcing you to not use an upfitter switch.
Not real sure why you made this comment, I didn’t say anybody was forcing anything I’m asking what you will need 6 uplifted switches for
I'm lighting up the world, mod bumper kit, SSc1 on end caps, LP6s on bumper, KC Era4 on A pillar and rock lights.
WuNgUn
Ontario Canada
2 door Squatched
Dude... You have wiring diagrams? Can you share?
Do you see anything for the rear fog?
redone17
Cold Spring, NY
I have this so far. I just request the layout/3D version.
Ford Bronco Factory Fog Light Switch 39878006-AC15-42C8-9014-0AA5F538B426
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
That last diagram makes sense why the BD doesn't have the connector. It seems the fog connector is on the same harness as the front sensors which only comes on steel bumpers with the high package.
WuNgUn
Ontario Canada
2 door Squatched
OH wow... Interesting observation 👍🏻
Wait....arent rear sensors standard? Only the front ones come with high pack and above...?
Or are you refering to the front fogs? 🤷🏻
Bigmoose
Jon
RI
Rear sensors are standard I think. Front only comes with high package. My BD is mid package and I didn't see any fog connectors.
WuNgUn
Ontario Canada
2 door Squatched
Rear fog wouldn't be optional in Europe though... So you may still have it
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
It is confirmed if you have the front sensors you have the foglight wiring. I just verified the it exists on my Badlands the passenger side and the wire insulation color matches. Does any of the after market lights have a compatible connector? if not it should not be too hard to make a jumper.
Ford Bronco Factory Fog Light Switch IMG_0843
Ford Bronco Factory Fog Light Switch IMG_0844
Ford Bronco Factory Fog Light Switch IMG_0845
Ford Bronco Factory Fog Light Switch IMG_0846
gizmohd
Darren
ModifyMike
ModifyMike
Ford F450
redone17
Cold Spring, NY
Damnit. So, it’s the sensors.
I’m hoping the wiring at least gets to harness near the battery junction box. But, this is a lot more work than I bargained for when it’s functioning as is using the AUX switch. I guess it will be something worth tackling if I need the switch for something more important.
Hanging onto the switch for now…
