Factory Fog Light Switch
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
That link doesn't seem to work.
Also I'm not sure what you mean by the gas cap button. None of the broncos have a gas cap button on the headlight switch, or anywhere else.
Hmmm, link works on my end. It's from Ford parts distributer. Some people were shipped the wrong part that had a trunk and gas button instead of mirror lights.
Ducati1098
Oh okay I see. I wasn't aware of that, but could explain the wrong part description.
Bruno
Bruno
Sierras
Whats the Part Number?
How much is it?
Bruno
Bruno
Sierras
Received my M2D-Z11654-BA:
I plan to hook up the Baja SAE Squadrons to front and eventually find a rear bumper that I like with additional reverse lights for the rear fogs.
Can you do a tutorial - I want to do the exact same thing
RDTC
Bob
WI
Ford F350, Jeep Wangler Rubicon, Bronco Outer Bank
AC switch doesn’t have the puddle or spot lights.
You would need DC for Lux package with front fogs only.
Don’t worry about the description on the website. It’s incorrect. AC and DC both are with blind spot.
I purchased the switch, installed it, and made the Forscan updates. Everything works great. I will use the fog light switch to auto turn off my Baja Design driving lights when the high beams are off.
Thank you for your help on switch selection.
da_jokker
Jeep Wrangler JKUR
Correct. All factory wiring. Both lights combined are 80 watts, 40 per side. So about 6 amps total
Just an update... So instead of buying cheap 14watt fogs, I canceled that order in purchased cheap 50w fogs ($25)
Each one drew less than 1 amp (think it was like 0.57 amps. So for less than $35 (with adapters) I was able to fill in the holes on my aftermarket bumper.
Ford Bronco Factory Fog Light Switch 20221222_174338
Ducati1098
Looks good! 👍
Sighlense
Upstate NY
Since folks have been asking us to buy these, we've put them up on on our site for pre-order
CrystaLux DT 4-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
CrystaLux DT 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
CrystaLux WP 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
The DT 4-Pin version is used on lights such as the Diode Dynamics SSC1, SSC2 and SSC3 w/BackLighting. It has the back-light control wire on it.
The DT 2-Pin version is used on lights such as the Diode Dynamics SS3 (without backlight), Rigid D-Series, KC HiLITES Flex, etc...
The WP 2-Pin version is used on Baja Designs S1, S2, Squadron lights.
We're expecting these AROUND May 16th and you'll get a pair of these.
Will any of these work with the Morimoto 4Banger?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
Unfortunately, a few really helpful posts in this thread were lost with d2dhanover's account being deleted. Some info provided that was really helpful and is no longer in this thread was some info on the plug for the existing factory fog wire harness tucked under the bumper shackle. It has an existing cap/plug end that is being used to keep the end water poof, and it can be re-used to connect the fog light to the factory harness. Looks like this:
Ballinger Motor Sports carries the parts (male pins and seals) needed to convert the existing cap into a usable water proof connection.
https://www.bmotorsports.com/shop/a...search_in_description=1&keywords=+CONN-100986
The males pins are: CONN-100986
https://www.bmotorsports.com/shop/product_info.php/products_id/4568
The seals are: CONN-56057
https://www.bmotorsports.com/shop/product_info.php/products_id/486
I know this might be long shot since its so long ago but do you know if this pigtail will work with fogs with bare wires on the ends?
https://www.bmotorsports.com/shop/product_info.php/products_id/4342
KhoiPhish
Altima
Sorry there's like 57 pages and I scrolled through several, anyone have instructions on how to swap the headlight panel to one with the fog switch.
Any screws i need to watch out for when pulling panels off?
Again sorry if its already explained
Stevervh
Waukee, Iowa
2021 Bronco OBX
I purchased a switch with front and rear fog light switches, but it doesn’t have the puddle light switches. I thought I could swap the puddle light module on my existing switch into the new one, but the circuit board doesn’t have the correct connection.
If anyone is looking to upgrade to the fog light switches and doesn’t have puddle lights on your Bronco, I’m willing to sell this switch. I originally paid around $85 for it after taxes and shipping. I’m willing to give someone a deal for this.
Ford Bronco Factory Fog Light Switch imag
Tallday
New jersey
Subaru Forester Toyota Highlander
I have been going blind scrolling through the 56 pages. Has anyone shown how the actual wiring plugs into the new switch panel? I added my own fogs to my base bronco that did not come with any. And want to take them off the aux switch. To me the road legal fogs don’t need a spot on my up fitters.
Tallday
New jersey
Finally. Done. Got the front fog light switch going to a pair of amber lights in the front. I added the diode dynamic reverse pod bracket with ssc1 pros. The wiring ties into factory tail/brake reverse lights so when my headlight are on, the red backlight is on low. When I hit brakes, the red gets brighter. When I put it in reverse, the white comes on in full power (zone lighting also turns them on). The kicker is that there’s a separate trigger input to turn on the white lights without being in reverse. I tapped into the white/blue wire in the door sill and ran that to the trigger wire. So I can turn on the white lights without being in reverse by hitting the rear fog light button. And the front/rear fog light icons on the dash work as expected.
Dude you are a wizard!! My brain hurts just trying to understand how that wiring works..
Nicely done!
Lymoon
Mo
Pittsburgh
Bronco Wildtrak
It is confirmed if you have the front sensors you have the foglight wiring. I just verified the it exists on my Badlands the passenger side and the wire insulation color matches. Does any of the after market lights have a compatible connector? if not it should not be too hard to make a jumper.
thanks. I found it, but how did you manage to release the plug from the bumper. It's too tight and I fear I might break something.
