Factory Fog Light Switch
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
thanks. I found it, but how did you manage to release the plug from the bumper. It's too tight and I fear I might break something.
I just pulled until it came loose. Actually, it disconnected from the body plug that was holding it in place. After which I was able to get a puller in there and remove the body plug and put it back on the connector. When I put it back I just barely inserted it into the bumper so it was easier to remove the next time.
orion
Jeremy
17' F-250, 17' Explorer
Anybody add the harness for fogs that didn't have fogs or sensors yet? I have a Black Diamond and no fogs, no sensors and was curious.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
You have to tap in before C203 (inside upper driver fender) brown and yellow/orange wires. I haven’t done it yet, but I plan to.
adamruiz2001
SoCal
Ford SVT Lightning
Sorry there's like 57 pages and I scrolled through several, anyone have instructions on how to swap the headlight panel to one with the fog switch.
Any screws i need to watch out for when pulling panels off?
Again sorry if its already explained
Are you talking about just removing the headlight switch and intalling the headlight switch with fog button?
If so, just slide your hand under the dash then push the headlight switch out from behind, it's that easy.
KhoiPhish
Altima
Yeah, i already did all of this! Ended up being super easy.
CarbonBronco
Tony
Socal
99 Toyota $runner
if you get to this before I do be sure to snap a picture of the wire at c203 as this would help guys with base rigs or similar with out parking sensors or c192 to tap to.
redone17
Cold Spring, NY
Yeah. I planned on putting together a full tutorial. I finally have a full understanding of it all - thanks to a few members on here - but, I’m surprised it hasn’t been well documented yet.
Agrod
SJ, PR
22 4dr OBX
Has anyone tried "fooling" the vehicle into having the fog light enabled switch with Forscan and triggering them on somehow? I really don't care about the physical switch, I just want to use the factory wiring and have the fog lights go off with the high beams.
I wonder how the vehicle registers that the fog light switch is on vs off...
swooshdave
Portland, Oregon
Mustang
I created a video of my process on my Badlands with factory fog wiring that might help some people.
I asked a couple questions on YouTube but I'll ask here too.
Where did you get the pigtails?
Do you recall which light switch you got? There seems to be a bevy of them.
BOPOH
Columbus, Ohio
Just fyi, 22 wildtrak LUX doesn't have rear fog light in the bumper pigtail
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
This is the thread I was looking at for the info:
Fog Light Thread
Pigtail URL
The light switch I swapped in was part: M2DZ-11654-DC
Lymoon
Mo
Pittsburgh
Bronco Wildtrak
Is there a way to connect front and back fog light to one switch (the one came with the car - wild track with modular bumper). Or do I have to buy a light panel with dual fog light switch?
Currently I managed to have my fog lights turn on on turns. kind of gimmicky but I'll keep it for now.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I wish there was a sticky for this. Maybe ModifyMike can update his original post with the pigtails we sell
CrystaLux WP 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
Used for Baja Designs Lights (S1, S2, Squadron)
Ford Bronco Factory Fog Light Switch 1675621099530
CrystaLux DT 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
Used for Diode Dynamics Lights (and other lights with a 2-pin DT Connector such as Rigid Industries D-Series). This is for non-backlit SS3 lights from Diode Dynamics
Ford Bronco Factory Fog Light Switch 1675621152359
CrystaLux DT 4-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
Used for Diode Dynamics SSC1/SSC2/SS3 (with backlighting) lights. Uses a 4-pin DT Connector. There is a short pigtail for the back-light control wire (which you'll need to extend IF you decide to utilize the back-light, to an upfitter switch)
Ford Bronco Factory Fog Light Switch 1675621184759
etmccaus86
Evan
Motor City
'22 BaseSquatch
Please do - going to be pulling the mod bumper this spring to install the Ford winch kit mount and figured that's the time to populate fog circuits. Would love to see what you encounter/ would recommend.
