Factory Fog Light Switch
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S, 14 JK Rubicon
Still digging, but I’m pretty sure the wiring is in place. My thoughts were for upgraded rear lights in the bumper (I personally haven’t seen an upgraded bumper I like just yet). Presumably they only activate when in reverse and switch is on.
The rear fogs are for visibility from the rear in fog. They are required in Europe I believe. I have a German driver’s license but I had to look it up to remember the rule as it has been almost 20 years since I took the test (required to convert my American motorcycle license when I moved there in 2002).
You use them when driving (forward) when visibility is under 50 meters.
German link, but if interested you can use Google translate:
https://www.adac.de/verkehr/verkehrssicherheit/wetter/fahren-bei-nebel/
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
ModifyMike
ModifyMike
Ford F450
Holy Moly how did this thread go this far without me getting an update! 😂 Anyway Great Information, my bronco will be built come next Monday then will be shipped so I’m expecting delivery in the end of October or Early November. Definitely keep us updated if you find the wires!
redone17
Cold Spring, NY
Just discovered that the IPC Module also has a Front Fog Lamps that presumably has to be Enabled separately from the BdyCM Module sections I posted yesterday.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Haven't seen this posted yet. Working on installing my flat towing system and found the fog light wiring and connects on the Modular bumper. The connector is right below the shackle bracket on both sides.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Haven't seen this posted yet. Working on installing my flat towing system and found the fog light wiring and connect on the Modular bumper. The connector is right below the shackle bracket on both sides.
Any pics Sir?
redone17
Cold Spring, NY
Flip sent me pics of this as well and I must be blind. I didn’t see it, but I already had the 3 Baja Design lights installed - so, it’s a little tight. I pulled the end cap off and plan to get back in there.
Ford Bronco Factory Fog Light Switch FC74AD4D-8215-4272-A2B2-074BDC72806A
I haven’t had a chance to go back to this project - but, the next two days are pretty open. Will report back on the switch too. My plan is to mess around in Forscan as well and setup Bambi mode of all goes as planned. I like being able to have the pods and high beams on at the same time on our dark roads.
ModifyMike
ModifyMike
Ford F450
My Bronco is in Transit to my dealer so if it works let me know and I’ll go ahead and order the switch. 😁
cparksjr
Clayton
Linden, MI
2021 Bronco Badlands, 2020 Ford F250 Tremor
Do you have the back up sensors in the rear bumper? That plug looks like the same as mine where those sensors are plugged in. The wiring color for the rear fog should be White with Blue Stripe for hot and Black with White Stripe for ground.
dcg2
Don
PA
Honda CR-V
Got a switch but no bronco yet 😂
Pardon me if I'm the slow kid. Is this the switch I want if I have a Badlands? And which P/N is it?
Thank you.
mds5917
New Jersey
Thank you.
I have a Badlands, and I ordered a slightly different version - M2DZ-11654-DA. That is the one with a single fog switch as if I am adding rear lights, I will make them work lights and run from the up-fitter switches, and only use the single fog to integrate my BD Fogs and have then run like factory fogs. That, however, requires some adjustments via FORSCAN to accomplish. I think this dual button version is the -CA
dcg2
Don
PA
Honda CR-V
Thank you very much for that clarification!
ModifyMike
ModifyMike
Ford F450
Yup he’s correct, I want to add Front and Rear foglight to mine hence the two fog buttons. One for the front and one for the rear.
