Factory Fog Light Switch
medic603
Bill
Delaware
2022 Ford Bronco Badlands
Connected my Oracle Fogs this morning, using the DT 2-pin to MX150 pigtails.
So easy! Saved me having to do any splicing/soldering.
Few minutes with Forscan, and I'm all set.
I used everything you used, and attempted the Forscan and still no power to my lights. Can you offer any suggestions I may have overlooked? Thanks!!
zedster
Bill
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
Did you buy a new switch?
Kjbeggs
Kelly
2019 Ford Ranger
Does your new switch work for everything else (headlights on/off, etc.)?
Did you make ALL the needed changes to enable the fogs in Forscan?
(three different areas)
1-BdyCM Configuration
2-IPC
3-BdyCM (As-Built Configuration)
Beyond that, I don't know what else you might check, as I was fortunate enough to not need to do any troubleshooting on mine.
medic603
Bill
Delaware
2-IPC
Yes, switch works for everything except front fogs. I have gone over all 3 sections of Forscan and all looks correct as well. I did do some experimenting and changed the “rear fog” setting to display on and that showed up but I only have the front fogs attached and the single fog light switch. Thanks for the reply.
zedster
Bill
Las Vegas
medic603
Bill
Delaware
I followed this post and the settings worked beautifully.
https://www.bronco6g.com/connecting-fog-lights-to-factory-wiring-harness-plug/
BdyCM Configuration
  • Front fog lamps - change this to "Enabled".
  • Fog Lamp Switch - change this to "Enabled"
  • Using Front Fog With High Beam - "Allowed"
IPC
  • 726-42-01-xxxx-xxxx-xxxx - Change the green value to 0101
That’s what I followed as well, not working.
Kjbeggs
Kelly
2019 Ford Ranger
I believe in the BdyCM (As Built) there are two lines, one for left, and one for right.
(Someone correct me if I'm wrong).
Check that
medic603
Bill
Delaware
Check that
I checked that too… have used a circuit tester and there is still no power to the factory plug
medic603
Bill
Delaware
Is there a chance there is a different power supply number/setting for the 2022 broncos?
Kjbeggs
Kelly
2019 Ford Ranger
dcg2
Don
PA
Honda CR-V
I am not quite sure what you mean, "Did you set them up as cornering lights?".
You can use Forscan to set the fog lights to be fog lights and cornering lights (one side or the other turns on when you turn the wheel) and are below 25 mph.
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Finished installing the Diode Dynamics Elite Series fog Lamps this weekend on my 2021 Base. I replaced the factory headlight switch with the front fog enabled one and made the necessary changes in FORScan. I am very pleased with the build quality and the amber backlight capability.
Beautiful Bronco!
We're happy to hear the positive feedback regarding our Elite Series Fog Lamps!
