Factory Fog Light Switch
LanCar
Sanford, FL
You can use Forscan to set the fog lights to be fog lights and cornering lights (one side or the other turns on when you turn the wheel) and are below 25 mph.
I wasn't aware that was possible, do you know what the FORScan settings are and in what module?
dcg2
Don
PA
Honda CR-V
BdyCM " 726-39-01" **xx xxxx xx-- Fog Light Usage: 00=Fog Cornering 01=Fog DRL 02=Fog DRL Cornering 03=Fog Only
So set it to 00 instead of 03 in the BdyCM module (not as built)
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
Hello, wondering if you may be able to assist me. I have the oracle triple fogs lights, changed to the updated factory switch with the single fog light switch, and used the 4x4TruckLEd adapter harness to connect to factory wiring, and have followed all the ForScan changes but still cannot get power to lights or indicator on the dash.
I didn’t have power to one of the lights at first. I didn’t have the patience to try and add another connector, so I cut and wired with butt connectors, and then it worked. I read you are not getting any power, so maybe reset forscan and start fresh. If that doesn’t work, check to see if the connector is faulty. Check for continuity and if they’re good maybe test factory wires before the connector. Chance of 2 bad connectors are minimal, but if you followed all the steps and the switch works otherwise…start simple and work your way up.
LanCar
Sanford, FL
Ok, thanks I will give it a try.
DenNut
Troy
Denver, CO
I removed (cut off) the factory connector and replaced it with a male weathershield connector that mated to the female connector on the harness 4x4truckleds provided
Any idea what the gague of the wire is on the factory harness? I'm trying to get all my supplies so when my lights arrive I'm ready. I have found waterproof connectors that range from 16 AWG down to 22AWG.
DenNut
Troy
Denver, CO
It is confirmed if you have the front sensors you have the foglight wiring. I just verified the it exists on my Badlands the passenger side and the wire insulation color matches. Does any of the after market lights have a compatible connector? if not it should not be too hard to make a jumper.
I have a Badlands with the High package. So it sounds like I will have these connectors. All these pictures are super up close. Where should I be looking behind my bumper? What did you have to remove to access them?
zedster
Bill
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
They are behind the plastic surround of the tow hooks.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
Sorry, that was a while ago…though that sounds like the range of the connectors I used
rwm01
Bob
2015 Roush RS1, 2023 Renegade, 2004 F350
Take the plastic surround off and they're easier to find. It just 4 plastic retainers. Easy to pop the retainers out remove the plastic surround with out tools.
DenNut
Troy
Denver, CO
Thanks. I have the modular bumper and don’t see any plastic, but I’ll look in that area.
Brianew
Seattle/Boise
69 Bronco, 08 Mustang, 2015 Wrangler
I can no longer find M2DZ-11654-DA sold anywhere, it says replaced by the BA version, but I think that is incorrect, due to the blind spot on the DA.
zedster
Bill
Las Vegas
Thanks. I
have te modular bumper, and don’t see any plastic, but I’ll look in that area.
There is plastic around the tow hooks. Watch any video on how to remove the modular bumper.
DenNut
Troy
Denver, CO
Earlybroncoboy
Wagner
Pa
22Bronco,76bronco,73bronco,06F250,96F250,97F350
Did you set them up as cornering lights? Probably my favorite thing about adding fogs.
Finished installing the Diode Dynamics Elite Series fog Lamps this weekend on my 2021 Base. I replaced the factory headlight switch with the front fog enabled one and made the necessary changes in FORScan. I am very pleased with the build quality and the amber backlight capability.
Did you tie them in at c203 or c192
