Fabricated own rock sliders
#1Broncogirl
#1Broncogirl
Carey
NW MT
2-Broncos, F250, E350, D90
Let's see the crawler. 😁
BTW looks like they just bend up some tube and welded it to the OEM rock sliders. Kinda like what @Tricky Dick did with his.
I tried to post, not sure if it worked I’m not good at this stuff
If this works well for you as a step but looks this minimal PLEASE share details. I love the look.
it was a custom build.
BAUS67
redneck
Central PA
The body mounts are actually pretty impressive. Like I said I’m not going to hammer it on the rocks. I have other toys for that
Nice!!! (y)(y) KOH 23 less than three weeks away. 😁
Ford Bronco Fabricated own rock sliders 1673225516151
BAUS67
redneck
Central PA
#1Broncogirl
#1Broncogirl
Carey
NW MT
#1Broncogirl
#1Broncogirl
Carey
NW MT
If you are in Hammertown stop by the 4WP race semi and say hi, ask for Carey
BAUS67
redneck
Central PA
Sorry, East Coaster here. Not gonna' make KOH but I will be watching my Ultra4 premium feed on the big screen. 😁
I did see that the Ultra4 schedule brings them to Pottsville Pa this year. Trying to make it to that race but some events have come up lately making it a bit harder. But I am trying.
Fmuguira
Frank
Idaho
Jeep TJ
I ve been dwelling on what to do also once my BL shows… thinking similar “extension” to BL factory rails and plating the tubing in to keep mud off doors, rockers and also give a step into rig. Would think the tube extensions would also protect doors from damage.
I’m not a big fan of mud flaps so this type of extension and plate would eliminate that need.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
I love those but they aren't aluminum and they don't fit with the rock rails. I REALLY like the look of the factory rock rails.
I mainly got them for the occasional rock, or tree trunk slip on the trail. And parking lot door ding-bats! And they make a good step
cynicalrider
First gen taco
How are these holding up? Couldn't get the stock rails on my Wildtrak but seeing OEM take off's going for $100 locally. Going to do the same for the errant stump/branch/rock. I have my Tacoma for the really dumb shit but this will get me by for a year or two till I get Metal Techs.
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
Very nice for what you need. I don't have the same skills or I would love to fab up my parts.
With sliders, I do look for the following:
How HD is it for bashing on rocks as I spend much time there
Can it double as a step
Does it stick out just far enough to keep door dings off it if it happens to be in a parking lot
broadicustomworks
Hanging Rock, North Carolina
I did the same sometime in the last year or two. Been a while.
Held up fine.
Function as a "Step"? Mostly. Better than no step or ones that clamp on and hang down a lot.
Function as a slider? Yes. I've had the weight of the Bronco on them.
Function as a "pivot off O' that yonder tree?" Affirmative.
Function as a "Dangit, Bobby I slid off of that ledge and hit the slider on a rock."? Yessir.
YMMV. I do not trust them for high speed crashing, pivoting around Redwoods at 50mph, or anything else that may be or viewed as illegal in 39 states.
But for a slider/step/door-ding stopper-getter? A-ok.
cynicalrider
First gen taco
Yeah I have a hard time trusting anything body mounted to be honest. I know a lot of other companies sell theirs similar to the ford setup and stick with the OEM mounting locations but I have seen my welded on sliders on my other truck flex enough to contact my pinch weld over time with just it getting beat on, I can't imagine something slowly tearing at the body. Also IMO good rock sliders will angle up to protect higher on the sill too without blocking the door. Also ideally a kickout would be at the end to pop whatever you are sliding against enough so your tire can also go in line with the slider path.
Held up fine.
Great to know. Got any pics of how far you came out with the tube? I am probably going to copy Tricky Dicks setup like below:
Ford Bronco Fabricated own rock sliders 277437017_4951674794914507_842166361458727718_n
But obviously 2 steps vs 1 and maybe a single connector in the middle as well like @#1Broncogirl did. I have spare 3/16 sheet laying around so I just need a stick of tube and some dimple dies and I'm looking at a set of sliders for $300 all in. Things I am taking into consideration of course are I doubt Ford had engineered these mounts to deal with the extra leverage bumping this slider out will cause so I likely won't be pivoting off these often. But if it saves a rocker from a drop off I may not have seen or just makes me feel better about taking this truck into rockier stuff I think I'll be happy with it. Plus anytime I bust out the welder I am enjoying myself.
I def won't be doing this kinda stuff that I do with the Tacoma with these:
broadicustomworks
I pretty much did what Tricky did.
Mine are angled down ever so slightly.
Enough that you can tell it when stepping on it with slick shoes in mud.
In retrospect I should have angled up.
I bought a set of 4dr weld on tubes for a JK and made my own dimple die plates, welded everything on, epoxy primer and Raptor Liner.
pretty pleased so far. They’ve done their job and when they no longer do I’ll fab up something heavier duty.
Ford Bronco Fabricated own rock sliders IMG_6093
Ford Bronco Fabricated own rock sliders IMG_8599
Ford Bronco Fabricated own rock sliders IMG_6836
Phil Brown
Phil
Santee Calif
03 F350, 1930 model A, 69 mach 1
This was my same thinking when I made these up
Ford Bronco Fabricated own rock sliders 20230825_153441
Ford Bronco Fabricated own rock sliders 20230825_153454
cynicalrider
First gen taco
Got a link to the tube? Would be easier for me to just get it and not hit up my buddy with a bender, but if it's more than like $200 I might as well just go buy the stick. That's exactly how I'll be doing it too but with two separate steps.
