Compta38
Alabama
Ford Fusion
I was top 25 at the sac.. 🦗 🦗 🦗
Where were you comp?
Chances we’re in the lucky 6?? 🤞
I believe I'm currently at number 16 if you take away the units scheduled. I'm really hoping they get more than 6 scheduled as I was kind of expecting to get in this round or next.
sidenote...I have a spreadsheet with people's builds and with 2 doors or Lux equipped trims which is constraint I'm in the top 8 as I have a 4 door with high package, no tow but the dreaded MIC.
Compta38
Alabama
Ford Fusion
Same here. I might even be tempted to change the color to the sand (or whatever they call that tan looking color).
I will ABSOLUTELY change to sand and that would be a big reason for the change to Everglades. I 100% want that color.
peterh
ny
jeep wrangler jlu 2018
i like those flares because they dont appear to lose coverage when compared to the current standard flare - i really wish the adv 2 inch flare didnt shave off an inch - makes a difference to me and i dont like how wide the 5 inch are - first world problems
Mackie
2018 Ford 150 Lariat 3.5L Ecoboost
Would be sweet if the drivers side front fender had a ‘matching’ opening with a snap in louver/vent. Then they should offer a matching passenger side louver kit that you could replace the snorkel with if you don’t need it or you’re not using it, store it in the truck for quick install when situation calls for it.
So when not using you have a set of Raptor like fender louvers.
vrtical
Doug AI
GSMNP, TN
Fords
maybe its headed to KOH.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Hoping those flares just clip on to the standard spots. I’ll be ordering a set.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
From what I've seen, there is no unique fender. The flare clips into the same wheel well opening as the current Bronco's fender.
peterh
ny
is the dang snorkel sticking out from the fender or the hood? If the hood then I am optimistic that we may eventually be able to order these fenders
NurseDan
Dan
Lethbridge, Alberta
2017 Focus
Would be really nice if they made all 2023's with the squared off fender flares. Looks much better than rounded.
Hope they don’t make these standard. Rounded look better :)
Hopefully an easy option for those that want it though!
Beach_Bum
Ken
St. Augustine, FL
I was referencing the flare/wheel well match up. Specifically for the Everglades, the passenger fender may be unique to that trim. But in general the square flares are plug-n-play on current Bronco trims.
peterh
ny
sorry i am still confused - are you saying that you believe the squared look we are seeing will be compatible with other trims or not? I won't hold you to it, but you seem to have good intel/intuition
Beach_Bum
Ken
St. Augustine, FL
The squared flare has been seen on fenders that were built in January 2021.
