Engine failure at 45k miles
bodie_38
Bodie
San Antonio
2023 Bronco Raptor
Truck is a 2023. I bought it used/certified at a Ford dealer in January with 35k miles and have taken it on several road trips without issue. Oil was changed at about 40k miles. About 100 miles from home on the most recent, a big orange wrench appeared on the display for a few seconds. There was no chime or scary alert message so I assumed it was a maintenance reminder. When I stopped for gas, I checked the app and saw that it was for "Powertrain Malfunction/Reduced Power" and instructed me to contact an authorized dealer as soon as possible. When I started driving again, I did notice that the power was reduced (no boost) and continued home for another 50 miles. It was Saturday night so I made an appointment to bring it in first thing Monday. I did not drive it Sunday but when I started it Monday to go to the dealer, it sounded rough and rattley. On the way, I got a momentary low oil pressure warning when I let off the gas but the measurement screen still showed 30+psi if I was on the gas so I continued to the dealer.
When the dealer finally got to it, they told me there was only about 1 quart of sludge in the oil pan and the engine was toast.
Ford covered the repair, replacing the engine and turbos but they can't tell me what happened. I KNOW 6+ quarts of oil were put in it at 40k miles and the dealer said there were no signs that it leaked out so what causes an engine to consume 5 quarts of oil in 5000 miles?
I'm taking it back this week because it feels underpowered. Normal driving seems fine but acceleration seems weak and it only shows 10 psi boost at WOT.
Has anyone else dealt with something similar?
Looking for opinions on what happened and advice if dealer claims "nothing wrong".
Thanks!
CitrusBronco
Everglades
Citrus county, FL
Everglades
I dont have an answer for you, sorry.
That’s a lot of oil consumption.
I suspect you changed the oil? Is that why you “know” 6 qts were added.
Well this is a good reminder for everyone that when a check engine light comes on, pull over and check.
VirginiaHeritage
Frank
‘25 Bronco HE
Your member info says Raptor. Is that the truck we’re talking about? I thought the 3.0 was a 7 qt fill.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
Thanks!
Who changed the oil?
bodie_38
bodie_38
Bodie
San Antonio
2023 Bronco Raptor
Yes, it is a Raptor. Yes, I changed the oil and yes I know the manual says 7 quarts. The dipstick read full at 6 so I put in another half quart. It showed over full at 6.5 so I didn't want to put any more in.
No leak - if it’s burning oil that much you would probably see smoke and gotten a code about it
Not many other places for 5-6 qts of oil to go in 5k miles
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Sorry to hear of your troubles.
Can you post a copy of the service write-up and invoice from the dealer’s service department? That will often document the specific codes, diagnostic procedures, and remedies applied in the technical language that Ford mechanics and engineers use to communicate. Someone here like @Ducati1098 might be able to read that and provide more insight. (Please redact any personal info before posting.)
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
Thanks!
My VW Rabbit started drinking oil, so much that I kept 2 quarts with me to add at every fuel stop. The Rabbit only held 4 qts. so 2 quarts was half the crankcase. No smoke visible and no external leaks. Turned out to be the valve guide seals were defective and oil was getting sucked into the combustion chamber. Maybe the previous owner neglected the oil changes, the valve guides took the brunt of poor lubrication and when the motor expired all that was left is the "sludge" in the oil pan? Definitely an odd malfunction
Tim Smith
Tim
Saint George, Utah
BMW X3M, GMC Yukon Ultama, Bronco
Some older owners' manuals for the Bronco 2.7-liter V6 misstated the capacity at 7 quarts; later manuals corrected it to 6 quarts. If you have a Raptor 3-liter V6, then it is 7 quarts.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
Purchased at a Ford dealer in January with 35k miles.
Oil was changed at about 40k miles. (What was the exact mileage at the time of oil change?)
What was the exact mileage that Saturday night when you stopped for gas and saw "Powertrain Malfunction/Reduced Power"?
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
OP, do you possibly have an aftermarket drain plug valve thing? Some of those do not fully drain the existing oil. The filter can retain oil if that wasn't changed, or if the engine wasn't primed or run a bit after filling, the new filter will absorb/retain some oil. Not trying to insult you with obvious stuff, but it may not be so obvious to everyone and could possibly explain the 6 quart fill.
Have you asked the dealer for the Ford service/recall history on the truck? Might also be worthwhile to check Carfax, though Carfax is not very reliable. I bough a used Acura that was shown having a clean accident history, and later found it clearly had been in some form of accident. If the previous owner was trying to hide serious issues/abuse, they certainly can. Hopefully the truck didn't belong to Whistling Diesel.
bodie_38
bodie_38
Bodie
San Antonio
2023 Bronco Raptor
Not sure how it matters but I changed the oil at 39,734 miles and I was at 44,962 when I stopped for gas.
It had the standard ford oil plug and I did all the priming. I reviewed the carfax before I bought it and it didn't show anything out the ordinary with oil changes at the dealership every 8k miles or so including just before purchase.
