Engine compartment fuse box removal advice?
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I want to lift my engine compartment fuse box to figure out how I can mount a bracket under or near it to mount an oil bypass filter behind it.
I have searched online for a video to help but came up with nothing. I can't find any information in my Ford Service manual either. Does anyone have advice has to how to remove this fuse box?
I am hoping I don't have to totally remove it but will if necessary. I have looked at it and can't see an obvious way to do it. I know the first thing to do is disconnect the negative battery cable and wait three minutes. From there I guess I will just have to start unscrewing nuts and see what happens if I can't get any advice here. I just prefer not to disconnect things I don't need to or will create a new problem.
Thanks for any help.
Squirrel13
Brad
KY
How much room do you need? I fabbed a bracket for my fuse panel. It uses existing holes near the battery tray
Ford Bronco Engine compartment fuse box removal advice? IMG_1944
Ford Bronco Engine compartment fuse box removal advice? IMG_1945
Ford Bronco Engine compartment fuse box removal advice? IMG_1942
BigMeatsBronco
Allan
2021 FE 2 door
I bought a smaller high capacity battery and then cut and bent the battery box to allow room for a remote oil filter...heres pics.
Ford Bronco Engine compartment fuse box removal advice? 20251109_144935
Ford Bronco Engine compartment fuse box removal advice? 20251109_145028
BigBend530
Dominic
Oroville, CA
2022 Ford Bronco 2Dr.
The battery junction box is mounted below the fuse block. The underside of the fuse block has electrical style connections and snap/clip into several relays below it. I believe the fuel pump relay is one of them. Each bolt (3 of them) you remove secures a different connector. These connections can come loose and cause total loss of power.
Lifeliberty
Moonbeam👀
Columbus, OH
1 minute mark, this is the only video I know of related to fuse box disassembly
swamp2
I bought a smaller high capacity battery and then bet the cut and bent the battery box to allow room for a remote oil filter...heres pics.
Come on you're just showing off now (as I would be too 😉).
BigMeatsBronco
Allan
2021 FE 2 door
I agree the workshop manual is completely void of any service instructions. Probably because the part is replaceable as a whole unit only.
gbub
gbub
Gary
Costa Mesa CA
Unfortunately, I need more room. I need the space behind the fuse box. I will keep this in mind if i can use it in any way. Thank you.
gbub
gbub
Gary
Costa Mesa CA
Great idea and install. I plan to use a higher capacity battery to power my refrigerator. I don't think I can make this work. Thanks for taking the time to share.
gbub
gbub
Gary
Costa Mesa CA
This is extremely helpful. That could get me to the point where I can see if there are bolts I can use for a bracket that I can fabricate and use for my bypass filter. I may have to go deeper but I don't know if I want to mess with that stuff. I will have to decide on that when I get there. Thank you very much.
