Engine clattering
ottawa
I have a 2 door 2.3 MT. The engine started making a loud clattering noise yesterday after 700 total kms. It isnt consistent but once it starts it doesnt stop until the vehicle is turned off. Took it to the dealer and of course they can't replicate what happened so can't/ won't fix it. No idea what it is but doesn't sound good.
Audio file attached
PWillette
Parrie
Maine
Yikes. Does the sound change if you engage the clutch? Sounds similar to a couple other recent threads. I believe at least one turned out to be bad output shaft on the tranny.
ottawa
No doesn't make a difference with the clutch depressed. Just got it back from the dealer today and again they don't hear any noise. It comes and goes but happened again right after I picked it up.
PWillette
Parrie
Maine
Go figure, seems to always be the case. May have to leave it with the dealer and have the service manager drive it for a couple days.
So is the chattering just start at random going down the road or is it just during start up when it's cold?
ottawa
drew707
Ford Explorer
Sorry what is the VHR? little hesitant giving out the VIN
Vehicle Health Report, cloud based service that lets techs see remotely any trouble codes that have occurred if the feature is enabled on the vehicle.
For privacy you can PM the VIN. Phil is a great guy and can be trusted for accurate help.
ROKBRNC
NorCal
2004 LJ on tons, 1970 Bronco, 2019 Tacoma TRD, 2022 Audi SQ5
I see you’re in CAN, did you mistakenly get the diesel option?
ottawa
After 300 total kms an engine light and soon after a service vehicle soon light came on. When the service vehicle soon light came on it went into reduced power. Immediately took it to the dealer and they said the code was for the turbo waste gate valve. Again they said everything was fine. Their response was that the vehicle was likely sitting for a long time and the valve was sticking. I didn't accept this and made them replace the valve. That was the first issue after 4 days. The noise that I posted earlier has happened before and after the waste gate valve was replaced. Currently no codes.
ByrdDogX
Jason
Olive Branch, MS
22 Ford Bronco
When I was at Bronco Off-Roadeo in Vegas my Bronco (#28) almost sounded like the piston was slapping. Instructor said it was normal, but sounded anything but normal to me. It was consistent through the whole day.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
Wastegate chatter could produce that noise, but I think it'd be higher pitched if it was. Had it happen on a BMW 335i I had. It's typically because it's adjusted too loose not because it's sticking. Does it go away when you're under boost?
