Eibach 2.0 upgrade
cbert5
florida
2022 bronco
Question. I am getting the 2 inch or eibach coilover upgrade with new UCA’s put on my 22’ outerbanks sas. I seen opposite opinions in whether or not to upgrade or get brackets to fine tune the rear track bar. Shop says things under 2.5 inches should not have to worry. And that most of what I saw online. I am just checking with you guys as this is my first Bronco. It will not be wheeled. Maybe just a little sand at the beach and high way and around town. Thanks for your thoughts.
Smocaine
DFW, TX
Cervelo Caledonia
I elected not to install a trackbar relocation bracket or adjustable trackbar with my Eibach 2.0 kit - I didn't even need UCAs to get a good alignment. I have kept the lift near the bottom of their range, and have not experienced any obvious adverse driving effects.
The RockJock trackbar relocation bracket that seems to be most popular calls for a minimum compressed length of the rear suspension that is longer than the Eibachs advertise. There are users on the forum that use the bracket anyway and have not had issues - this may depend on lift height and other factors.
87-Z28
Andy
BMW
I have 6100 bilsteins. They are pretty much the same as eibachs. I am on lowest setting to keep my CG down, <2 inch lift. No need for new front UCA to get back to oem alignment. Or rear track bar modifications.
I suggest you just do the shocks and see how it is. If you are wanting to be near highest lift setting then reevaluate.
