Easiest B&O upgrade?
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
what about the center? i wonder if i need to upgrade the middle dash or if the corners will be ok by themselves?
The middle is important. I bought two pairs of the Hertz and a Pair of Infinity. I played around with them and liked hertz in the rear and center front and Infinity in the corners. I want to add power to the kick 6” to help move the lower frequency sound stage forward a bit.
BadBuckeye
C-Bus
tbruz
Tony
NH
1997 Tahoe 2-door, 1976 Bronco Ranger
Badbuckeye,
I'll split a set with you. Will need to figure out the logistics-and split a set of harnesses as well.
Tbruz
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I know this thread is somewhat old, but it's surprising how much better the system sounds with turning off the active noise canceling nonsense with Forscan. It's crazy that someone at Ford hasn't realized that they are actually making things worse with that really crappy 'feature'
Brian2011
massachusettes
2024 Toyota Tacoma
What part of forscan is that everything I have read say factory settings for the B/O system are the better bet? even with upgraded 6.5 rear pods, have not seen anything definitive for changes to forscan for better sound,
DriveAllNight
Dan
N.J.
Ford Bronco Easiest B&O upgrade? 1000006907
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Am I the only one that thinks the B&O 10 speaker system sounds good??? :oops:
Not at all, I have no issues with the B&O, in fact I have an Alpine 5 channel amp & JL Sub ready to go and haven't found the need yet! lol
I am currently driving a Charger Hellcat while my Bronco is in the shop. It has the Alpine system in it. It's probably a bit louder than the B&O, but the B&O blows the Alpine away in sound quality!
mx6bfast
Dennis
Delray Beach, FL
OBX, son's 08 Civic, wife's biz 22 Camry Hybrid
I got the sides replaced no issues. I can’t get the screws off from the accessory mount in the middle. Do you recall were the screws straight up and down, at an angle? I read t-20 but I can get it to move.
jehines3
Easton, MD
They are at an obscure slight angle forward towards the windshield. T-20 sounds right, but Just take a variety of 1/4 drive torx bit and a ratchet set up with 1/4” socket. I used a piece of electrical tape to get a tight friction fit, bit to socket, to keep it from falling off.
mx6bfast
Dennis
Delray Beach, FL
Thanks. I tried for 15 minutes, literally 2 after I posted I got them off. I had to change my ratchet to a smaller one. Just needed to post I guess. 🤣 didn’t pop any clips. 🤣🤣
All 3 fronts are replaced. Still holding off on the kick panels and sub. I can tell a difference in the dash speakers, much crisper and the voices are easier to hear.
Still debating on forscan. Will it make any noticeable improvements to the sound since all I’ve done is alpines in the dash and 6.75 kickers on the roll bar?
jehines3
Easton, MD
there are a lot of functions in the sound settings of the unit, I doubt forescan can unlock some secret DSP functionality. I did the full rear sub panel clip apgrade and dynamat in the cargo area. I added rubber isolators to all the sub box hard mounting points. That really helped. It’s still missing mids and lows forward. I’m gonna use the highest efficiency kicks panel 6” single voice coil I can find.
Johnny Mo
Westchester County, NY
teachu2shoot.com
Memphis MJP6.
dmhalka
doug
Audi
OK, first off, Thank you! You are indeed correct about these speakers. I just swapped the B&O 4” dash speakers with the Alpines you are 100% correct, night and day! Took about 20 minutes to do!
Another thing I have to rant about, I honestly cannot believe this system is advertised as a B&O system. The 4”s I pulled out are pitiful. I just shook my head after picking it up, pitiful/shameful.
The only other thing I have done is supplement the lows with a Kicker HS4610 behind the drivers seat. I am afraid to even look at the quality of the other B&O speakers.
Hi, I know this thread is old, but I'm just picking it up. I'm curious how you connected the Kicker to the system? Did that replace the sub in the back?
