DV8 Storage Compartment reviews / experiences?
psdtime
Tom
CA
2026 Bronco
I was able to find a discount code for the box and another for a Corsa exhaust. They are my father's days presents from my kids, of course they don't know about it (college fund raided 😁), I hope they are smart enough for a scholarship or dumb enough for full government assistance!
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
What was the code? 😁
psdtime
Tom
CA
2026 Bronco
Storage box to show on Thursday and the exhaust inexplicably showed up today. I ordered both yesterday (Sunday). For those who have installed the box, if I install the exhaust before the box, can I leave the factory heat shield in until I have a chance to install the box or is it going to create a bunch of extra work?
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
Mine went in super easy. I have the Steeda axle back exhaust so the factory heat shield was very easy to get off. The factory muffler was easy to get off as I remember as well, in case you still have that in place. I had no problem holding the box and top trim panel in place by myself to put the bolts in. The only thing I added was a very thin weather strip around the perimeter as the factory box had. I did not want any water spray to find its way up around the trim panel into the Bronco. Probably not really needed but the factory box was sealed so I added it just in case. It's a very well made box and I got quite a bit of stuff in there. I put a few small things in the jack area also but they could easily go in the DV8 box. It is very loosely packed,
Wow, you are an amazing packer! Even though the DV8 bin is larger, that is still a lot of stuff.
Rydfree
Benny
Alabama
The heat shield on my 2dr had 4 10mm bolts and two push
pins. It was simple to get to on mine. You can just give it a tug after the 4 bolts are out and the push pins will pop out.
KreeHBronco
Kevin
Bay area California
I went ahead and removed the heat shield when I installed my Steeda muffler. It was easy without any muffler in place, plus there was a significant air gap between my new small exhaust and the OEM storage box. Once this is done, you can install the DV8 box from the top with no need to go under the vehicle again.
psdtime
Tom
CA
2026 Bronco
Do you happen to remember the width of the weather strip that you used? Got the exhaust in last night. Hopefully will get the storage container in by Friday.
Rydfree
Benny
Alabama
3/8" that I had lying around in the shop. I stuck it to the truck along the perimeter of the factory hole. I did not want any metal to metal contact between the box and the truck that might start squeaking plus there's a slight chance some water intrusion could get up in there. Seemed to work well.
Frost King 3/8 in. x 5/16 in. x 10 ft. Black Rubber Foam Weatherseal Tape R538H - The Home Depot
psdtime
Tom
CA
2026 Bronco
psdtime
Tom
CA
2026 Bronco
Got it installed last night. Extremely easy job. Very happy with it. Top notch quality.
Mean Green
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
Anyone do the install with a body lift? I have a 3/4 inch body lift and Ford Performance muffler. I’m assuming the shield is attached to the body and has to come off no matter what.
psdtime
Tom
CA
2026 Bronco
The heat shield is mounted to the body. You'll have to remove it. The good thing is you'll have a bigger air gap between it and the muffler.
Mean Green
Warminster, PA
Body lift helped for sure. I was able to remove the heat shield without touching the muffler. I was also able to install it from above. Took me only an hour because of this. I reused the Velcro latches off the old one as well to hold the lid down. Factory unit did have a gasket installed on it…
Ford Bronco DV8 Storage Compartment reviews / experiences? IMG_5215
Ford Bronco DV8 Storage Compartment reviews / experiences? IMG_5214
Ford Bronco DV8 Storage Compartment reviews / experiences? IMG_5222
