DV8 Offroad | Rear Inner Fenders
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
Looking for an upgrade over the plastic factory rear inner fenders on your 2021+ Ford Bronco? Our 6th Gen Bronco Inner Fenders are just what you need! They're crafted from lightweight aluminum panels and finished in a weather-resistant satin black powder coat. They feature aluminum mesh accent panels that can be removed and painted to match your Bronco's body color.
These inner fenders will fit tire sizes up to 37-inches on Sasquatch package equipped models, and no lift is required for fitment. Installation is simple, as these are a direct bolt-on replacement for the factory plastic inner fenders.
Key Features:
  • Lightweight Aluminum Construction
  • Satin Black Powder Coat Finish
  • Paintable Aluminum Mesh Panels
  • Included Black Hardware
  • Cleans up the Inner Fender Area
  • Simple Bolt-On Installation
Check it out here: https://dv8offroad.com/products/6th-gen-bronco-inner-fenders-rear
Technical Specifications:
  • Fitment: Direct Fit
  • Material: 1.5/2mm Aluminum
  • Finish: Micro-Texture Black Powder Coat
  • Paintable Mesh: Yes
  • Weight: ≈ 14 lbs
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
More intrigued about those fender flares
Those should be released here in a few months! We have quite a few new products releasing in the coming weeks!
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Very intrigued, so you're saying with this fender liners there is no rubbing at full compression or lock with 37's on stock Sasquatch suspension? No body mount chops or anything needed?
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Correct!
Ground_zero298
Scs michigan
