- Mar 17, 2022
- 83
- 224
- 398
- Riverside, California
- Website
- dv8offroad.com
- Bronco's & Jeep's
- Badlands
This Bronco Rear Bumper is part of the MTO Series (Made to Overland), and is compatible with all Bronco trim levels. Manufactured from high grade steel, it was designed to protect the rear end while maintaining high ground clearance. We've placed the license plate mount at the side of the bumper, in order to accommodate the Sasquatch package 35-inch tires, and to ensure the tail gate swings open freely. The bumper can fit up to a 37-inch tire on the OEM carrier above. Included with the new license plate bracket are license plate lights.
Two 3-inch flush mount pod lights can be mounted towards either side of the bumper. These can be wired to the reverse lights, or to a separate wiring harness in order to provide supplemental lighting at the rear of your Bronco while on the trail. There are 2 clevis mounts that take 3/4-inch D-ring shackles that provide recovery options. The MTO Series bumper includes sensor holes to retain full functionality of the factory backup sensors.
Key Features:
- (2) Mounts for 3" Flush Mount Pod Lights
- Reinforced D-Ring Mounts
- 2-Stage Micro-Texture Black Powder Coating
- Retains Factory Backup Sensors
- 4mm Body and 5mm Mounts/Supports
- Paintable Aluminum Mesh Panels
- Accommodates up to 37" Spare Tire on OEM carrier
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
