DV8 Cargo Box Replacement
allenill3
Orlando, FL
Bronco Raptor, Rubicon 4xe, F150 Raptor
Just replaced this today to get some extra out-of-the-way storage. There’s much more space with this and it can even fit an ARB twin compressor. I have the AGS tailgate kit ready to install so I won’t be using it for that, but I’m going to see about fitting a Redarc system and LifePO4s in there.
I don’t need the original box so if anyone wants it, just let me know. Pickup in Downtown Orlando or can ship at your cost.
Ford Bronco DV8 Cargo Box Replacement IMG_0621-compressed
Ford Bronco DV8 Cargo Box Replacement IMG_0622-compressed
Ford Bronco DV8 Cargo Box Replacement FullSizeRender(2)-compressed
Ford Bronco DV8 Cargo Box Replacement FullSizeRender(1)-compressed
Ford Bronco DV8 Cargo Box Replacement FullSizeRender-compressed
BroncoRunner23
2023 Bronco
Been wanting to do this for the extra storage. Have you felt if it gets hot after a drive ? Since you have to remove the oem heat shield. I know it comes with its own that you double side tape to the bottom but wonder if it works as good as the oem one.
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
Did you block off all the holes on the one side, or is that just open to the road below now?
allenill3
allenill3
Orlando, FL
It comes with drain plugs and a water resistant membrane/sticky pad that should prevent anything from coming up.
allenill3
allenill3
Orlando, FL
I love me some storage, but I don't think I'm ready to take an angle grinder to my Bronco body.
This is a drop in (actually, pull up from below if not a Raptor) replacement. No angle grinder needed!
allenill3
allenill3
Orlando, FL
I just touched it after an 20 min drive and it’s not even a little hot. I’ll add that the heat shield on this is much more substantial, OEM don’t even cover the entire length of the box.
Gtrekker
Gary
Yep, feeling that grocery getter / 4dr envy here.....
Wish there was one for a 2dr.
Team 2 Door = Purpose Built and Bad Ass 👍 🤩👍
allenill3
allenill3
Orlando, FL
Haha well it’s not THAT much more storage. Could probably fit a 6er on each side though, with some ice!
I would be all over a 2 door if that was an option on the Raptor.
GI_Jo_Nathan
Jonathan
I thought the boxes where the same for 2 and 4 door?
Gtrekker
Gary
No, I just have an equivalent to a glove box
Yeah, it's not much... and Hell Yeah on a 2dr Braptor!!! 🤩
Team 2 door = 😎
Gtrekker
Gary
No, I have an equivalent to a glove box in the back. May be looking at cutting one in once once the other upgrades are done...🤔
GI_Jo_Nathan
Jonathan
Oh ok. I have a 2 door as well, mine is the same as OP's. The rear section of all Bronco's is identical underneath behind the axle.
JEMSA
Phoenix
70 Bronco, 82 F350, 91 MX5, 93 MX5, Bronco
I’m with you on the 2DR aftermarket / storage envy. Where and I going to put that fridge? But I’m too used to my ‘70 to go 4 door. Still catch myself reaching for the column on occasion when I clutch my ‘21.
GI_Jo_Nathan
Jonathan
I don't understand why y'all keep saying the 2 door storage box is different. As far as I know it's not. DV8 doesn't even say this is more door only.
