Driver window unsealing in wind
TrailDust
Adam
Nebraska
23 Bronco, 23 Bronco Sport, 97 F-150, 07 Cummins
So I live in Nebraska, a wind hole where 20-30 mph winds are very common. Took the Bronco on its first road trip and ended up driving west on the interstate with a 20-30 mph cross wind coming directly out of the north.
Probably the most miserable drive I've ever had.
Driver window constantly popped open, pulling away a good quarter inch with wind noise so loud couldn't hear anything but. Stopped multiple times to reset window, kept happening. Ended up having to drive 2 hours with this nonsense. Thought the window was going to tear off with a few of the heavy gusts.
This is a game changer for me. I've had multiple frameless window vehicles and never experienced this. A few whistles during gusts but not the window pulling away and fluttering in the wind. Wind is not going anywhere but this Bronco sure will if this is the norm.
Has anyone had this happen? Is there a fix? Search only keeps bringing up the reset thing but that's not the issue. More like it needs to angle in more to catch the seal, or more up pressure at closing?
Here is a picture while driving.
Ford Bronco Driver window unsealing in wind IMG_20230415_120304561
BeachTiger
South Carolina
2019 Ford F150, 2022 Bronco Badlands
HeliPilot
Kenny
CT
2022 2.7L SAS
Mine did this in the exact same scenario. I looked along the window edge to see where the window was barely catching the seal on the bronco (even compared it to the passenger side to see what the difference was between the two). I then rotated those sections downward on the seal itself (grabbed with a firm grip and twisted downward the best I could). The seal rotated enough that it hasn’t happened again in strong crosswind over last 7000 miles. I also did the whole window reset thing too.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Yes. My passenger window does this. So far I’ve not been able to find a local dealer or competent shop that claims to know how to remedy.
Took me 2 months to get an appt at a local dealer that “appears” to be polite & competent. I plan to ask them about it again.
KABQ
Aaron
Albuquerque, NM
I had the same thing happen, but my window came misadjusted from the factory, which in this case I guess was a good thing. It over-engages and gets caught on the overhanging strip every time I open the door, but that also prevented it from being pulled outward too far while driving.
TrailDust
TrailDust
Adam
Nebraska
Will give this a try first, thanks!
TrailDust
TrailDust
Adam
Nebraska
Here is a video that I used to fix the same issue.
Thanks, gives me a little hope there is some upward adjustment if messing around with the seal doesn't work.
TrailDust
TrailDust
Adam
Nebraska
Looking a little closer check out the difference in the open door down position, door just cracked open but still latched.
Driver
Ford Bronco Driver window unsealing in wind IMG_20230416_171841160
Passenger
Ford Bronco Driver window unsealing in wind IMG_20230416_171907751
Then check out how the driver side windows are tilted a bit outward, a gap between the B pillar on the driver side Vs flush on passenger.
Driver
Ford Bronco Driver window unsealing in wind IMG_20230416_195737447
Passenger
Ford Bronco Driver window unsealing in wind IMG_20230416_195807212
So shows me the window on driver front needs adjusting upwards, plus both need tilted inward. This is a Ford problem, going to call for a dealer appointment. Supposedly the Mustang has had same style window? Surely Ford techs have to have seen this before right?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! If you'd like to, go ahead and send us a private message with your VIN and dealer info and I’ll look into this window concern. Thanks!
Ford Motor Company
Dearborn
Hi there. This window concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
WyoBronc
Kerry
Wyoming
2021 Ranger, 2021 Bronco BB, 2006 Saturn Vue
I had the exact same thing happen to my bronco on the interstate between Cheyenne Wy and Fort Collins Co, where the crosswinds were between 65-75 mph. Since the window wouldn’t seal I had to roll it down further and hold onto it while driving to give it more stability and prevent it from breaking…..which was a bitch because the wind chill was about 8 degrees below zero. I pulled over a couple time and reseated it, but it just kept happening.. Then, last week the window wouldn’t drop properly when opening the door and wouldn’t go up at all when closing the door. It would seal if I manually opened then closed the window, but the one touch up and down function stopped working as well. I scheduled an appointment with Ford for next week, however, now it’s working fine again on its own. I’m keeping the appointment anyways.
TrailDust
TrailDust
Adam
Nebraska
Serpent51
Joel
Minnesota
I'm having the same issue. Brought it to the dealership twice to be fixed and they
don't know what to do. Loudest 5 hour ride ever.
