Downfire subwoofer install
JonB2
Jon
North Hollywood, CA
2025 Ford Bronco 2-door
Hello,
2025 Bronco base 2dr. Looking to install a 10" downfire subwoofer in the rear cargo area. Already have amplifier mounted up front so just need to run speaker wire.
1. Any thoughts of best way to run the speaker wire? Was thinking of just running under the side panels to the rear.
2. Are there any quick disconnect options and how would that mount?
Thanks!
Run the wiring down the door sills - they already have wiring passages built into them, easy to run it from front to back.
If you are running really large gauge such that that won't work, then under the carpet is another option.
Disconnects - for power - Anderson connectors are the standard. For audio - RCA jacks or banana plugs if your amp doesn't have some sort of custom harness
23OBX2.7
AB Canada
2023 Bronco
Some loaded enclosure like Hertz and Audison have quick disconnects incl and down fire block spacers incl though easy to do your self besides its only two press buttons to remove wire
JonB2
JonB2
Jon
North Hollywood, CA
Great thank you for the responses!
