Doors off, brakes change
Oldkat1303
Tim
Tennessee
Got my top and doors off, after getting a lift and door cart from EZ4X4, and noticed that, when my door are off, the brake peddle is squishy at startup. It firms up as soon as the engine starts and when I put the doors back on.
Anyone else noticing this? Is there’s something from Ford on it?
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Your profile indicates that you have a MY'21 Bronco. What engine - 2.3L or 2.7L? The older 2.3L has vacuum-assist brakes. The brake pedal on those models will be "soft" until pressure builds.
mjp2
NJ
2021 Cyber Yellorange Bronco Badlands
As to the cause/effect mentioned in the thread title, the door seals help maintain the vehicle's vacuum pressure. With the doors off, all that vacuum is lost.
It doesn't happen if you park with the windows down or when the top is removed because the truck's computer doesn't monitor the state of the windows or top.
It's like gravity in cartoons -- it only takes effect when someone notices.
Beach_Bum
Ken
St. Augustine, FL
I made no mention of the OP's attribution. I just tried to offer an explanation if they had the older 2.3L.
mjp2
NJ
I was hoping my post was silly enough to be obvious satire. 🙃
Your answer is THE answer and the doors-off thing is 100% unrelated to the brake pedal.
Beach_Bum
Ken
St. Augustine, FL
I was picking up on the satire. The doors-off causation is 100% unrelated.
OP hasn't responded back. But we have been here long enough to know about complaints regarding the "soft/squishy" brake pedal on the MY'21-MY'24 2.3L and the vacuum assist brakes. Many people have never drove a vehicle with such a system and expect the behavior of EBB systems.
kodiakisland
Arkansas
My '21 2.3L on 37s has great brakes, but I learned to drive 60's and 70's vehicles with no power brakes and probably only one of the 4 drums making contact, so I know bad brakes.
Oldkat1303
Tim
Tennessee
Thanks for the info, it matches what I found when I researched the issue; however I have the 2.7 with electric brake boost, which is why I’m confused.
mjp2
NJ
Well that adds a new wrinkle to the question. Unfortunately, as with my initial post in this thread, I have nothing beneficial to add.
shaw
shaun
California, Santa Clara
2024 Bronco
That's interesting. I haven't experienced it myself, but I'd be curious if it's related to the door-ajar logic or another system check that runs when the doors are removed. If the pedal feels normal as soon as the engine starts and everything goes back to normal with the doors reinstalled, it may be expected behavior rather than a brake issue. Hopefully someone who's regularly runs doorless can confirm whether they've noticed the same thing or if Ford has released a TSB or service bulletin on it.
