Door stuck trying to remove
Bob4RE
Robert
Charlotte NC
2021 Bronco 4DR Badlands
I have taken both bolts out and disconnected the wiring harness, but the door will not lift off the hinge. Help
2021 Bronco Badlands
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Did you roll down the windows and fold the mirrors all the way forward?
Dmorty217
Derek
Venice FL
Camery
You might have to put some ass behind it if the doors haven’t been removed before or in awhile. Make sure you have the two front fender protectors on to avoid damage to the paint (very helpful with reinstalling but may come in handy since they seem to be stuck) is it both doors or just the one?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Fender protectors? Never seen these.
Bob4RE
Robert
Charlotte NC
I have only tried the passenger front and back. Both are stuck
‘21OBX
90Bronco19
2022 bronco outer banks
Just to be safe you did take out the silver bolts that go vertically in each hinge correct? If so then I would use a small pry bar and an assistant. To gently lift at the hinge. The maybe 5” long rubber strips that come in your tool kit to protect the paint should be used on the leading edge of the door at the top and lower body line so you don’t chip the paint. You do have to lift evenly and straight up.
Dmorty217
Derek
Venice FL
Camery
It’s in the bag with the socket set. Two little silicone type protectors that slip on.
Ford Bronco Door stuck trying to remove IMG_4124
Bob4RE
Robert
Charlotte NC
Yeah I took both bolts out and disconnected the wiring harness.
Dmorty217
Derek
Venice FL
Camery
If pulling up on the door from the handle and spot on the lower front isn’t working I would take it to the dealership and as them WTF is wrong. Have you ever had the doors off?
da_jokker
Jeep Wrangler JKUR
They only need to lift like 1" so be careful. If you are lifting super hard and they suddenly get unstuck, they will pop up to high and start hitting things.
I mean the doors do weight like 50lbs but I just took mine off for the first time and was surprised how easy they lifted up.
You do need to go straight up, no angles. GET HELP and have one person just support the outer part of the door, while the strongest person lift straight up directly on the hinge edge.
Windows down, doors unplugged, 2 bolts removed, and doors opened about 45 degrees.
Bob4RE
Robert
Charlotte NC
Thanks all for the advice. With the help of a friend I was finally able to get the driver side off. The mount points were rusted. The passenger side came off easily as designed.
Ford Bronco Door stuck trying to remove 20230706_131659
da_jokker
Jeep Wrangler JKUR
Glad you got them off. I'm surprised it was rusted..maybe they forgot to grease that one.
