4 door hardtop remover tool / device ?
2018 bigdog
Charles
illinois
2018 Tundra
what are most of you using to remove the hardtop off of your 4 door Raptor besides your hands lol ?
Jadon79
New England
Corvette z06, Range Rover Sport, Bronco Raptor
Just picked this up.
Shawngod5269
Shawn
Marlton, NJ
2024 Raptor
I have the EZ4x4 hard top lift and use a m12 Milwaukee ratchet for quicker removal of the 12 Torx bolts
bojibronco
des moines
2025 4dr Sasquatch
I’m also using a ryobi battery powered racket. The amount of time that saves is incredible.
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
I have the original Top Lift Pro and it works wonderful! You can store your top pieces on it and move it around the garage as needed. I did make a support piece that goes from the base up to the lifting platform when storing the top on it because it can be a little unstable (bouncy) if you don’t have one. I don’t think it’s necessary, but I just didn’t want to take a chance. This being the original version you can probably pick up secondhand pretty cheap.
Ford Bronco 4 door hardtop remover tool / device ? IMG_3076
Ford Bronco 4 door hardtop remover tool / device ? IMG_3087
Ford Bronco 4 door hardtop remover tool / device ? IMG_3086
2018 bigdog
Charles
illinois
2018 Tundra
is that the EZ LIFT ? iF SO I WAS CONSIDERING THAT ONE BECAUSE I LIKE THE LIFTING MECHANISM. WHAT WAS THE PRICE AND WHERE DID YOU GET IT ? SORRY FOR THE ALL CAPS!
2018 bigdog
Charles
illinois
2018 Tundra
Just seen it is the EZ LIFT so what was the price and where did you purchase ? Thought you could store the top on the lift ? You don't ?
MayhemMike
Mercury
Unless you are physically limited there is no reason to purchase a top removal with a four door Bronco. The clam shell section is small and easily manageable by two people. One person could do it if they are not physically limited. The two door clam shell is a much larger section. Two people can also manage its removal but a lift or harness system is strongly recommended if trying to remove alone.
Jadon79
New England
Yes got it on Amazon for like 600bucks. Ordered it Sunday showed up Thursday. It’s stout!
2018 bigdog
Charles
illinois
2018 Tundra
Do you not store the top on the lift ? It says you can that’s why I’m asking
drewski
Greenville
2018 Ford Mustang, 2007 Toyota Tundra
Wouldn't happen to have a pic of your "support" would ya? I have decided to build one myself just to take the stress off the top and put the weight back on the sides like it does when installed. Looking for ideas. Thanks
