Door reinstall devices
Big Betty Blue
Amy
Cleveland, Ohio
2025 Bronco
I'm looking for something to help reinstall my doors. Taking them off is fairly easy. Putting them back on is horrible 🤦‍♀️ I'm looking for something with a small footprint. I found this by Raezum Door Lifts (https://jeepdoorlifts.com/) but they say the Bronco version is under construction. So that has led me too look at the Steck EZ Rest via eBay. Any suggestions?
Ford Bronco Door reinstall devices 1000102830
Ford Bronco Door reinstall devices 1000102832
not on the rug
NJ
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
Putting them back on is just like taking them off...but in reverse. 😂
What is the difficulty you're having with putting them on?
Big Betty Blue
Big Betty Blue
Amy
Cleveland, Ohio
2025 Bronco
Arm strength and wing span. They are too heavy for me to line up and hold. The precision needed for reinstall is nothing like the uninstall.
kodiakisland
Arkansas
Are you using the supplied guides?
Big Betty Blue
Big Betty Blue
Amy
Cleveland, Ohio
2025 Bronco
Do you use the alignment pin?
EZ 4x4 makes an alignment pin guide kit that might help you out.
Yep, have those and the bags. Love the bags for uninstall, storage, and the attempt at reinstall but really struggling with reinstall - lining up the top and bottom just isn't working. Also just bought windshield washer hose tubing to use instead of the stupid 2 pieces of 4" door edge protector for the reinstall too.
kodiakisland
Arkansas
Even with the bigger doors on the 2 door I don't have a problem, but maybe it's an arm strength issue. I just stand on the inside of the door, look down and set both hinges onto the pins. It's pretty easy for me. Are you standing on the outside of the door where you can't see the hinges?
not on the rug
NJ
I don't know how the bags would help with uninstall and reinstall. Just grab the doors where they say to and lift straight up to remove. To reinstall, use the guide pin, stand where you can see the hinges with your own eyes and slide the door back in place.
I've never used the rubber protection strips and I rarely even use the guide pins. They go back in place pretty easily.
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
Badland-Mansquatch-ATX
Ron
Austin, TX
2022 Bronco, 2025 Lucid Air
There may be a variety of reasons why the doors are too heavy for a person, from body size to age to disability. The Bronco doors are much easier than the Jeep doors (I used to HATE putting those on).
I also prefer using the bags to lift and position them (helps protect them if I were to drop one or bump the side). However, if they are just too heavy, getting a second person or some jack lift-based tool may be your best choice. Maybe use some everyday options like a rolling single drawer office file, sofa ottoman, four wheel dolly with a foam block or rolling step stool. Something like this one could useful around the house as well, and it’s 20” tall (where my Badlands Sasquatch measures). https://www.uline.com/Product/Detail/H-2251Y/Ladders/2-Step-Utility-Step-Ladder-Yellow
Target has these, but at 14”, you’ll need some additional padding on top: https://www.target.com/p/costway-ki...rm-330lbs-capacity-gray-backless/-/A-88224652
Draughon
Daylon
Dallas
BMW 4-Series
On a 2D - it's even worse!
Draughon
Daylon
Dallas
BMW 4-Series
I think this would absolutely work on 4D Broncos... for 2D it could be adjustable to make it a bit wider on the base to support a longer door, but this looks promising.
Draughon
Daylon
Dallas
BMW 4-Series
That Jeep door lift is $750..... I bet you could buy something like this, and just add 4 posts to the corners with pool noodles and do it for under $200.
https://a.co/d/0eB13kuf
Ford Bronco Door reinstall devices 1780845565789-bg
Big Betty Blue
Big Betty Blue
Amy
Cleveland, Ohio
2025 Bronco
Big Betty Blue
Big Betty Blue
Amy
Cleveland, Ohio
2025 Bronco
I'm standing on the inside but I'm vertically challenged :) (5'2") and just don't have the strength. I love the bags for holding it and essentially protecting it for not just the removal but while they're sitting in the garage. But the reinstall is killing the vibe!
