E_Cups
Ed
Louisville, Ohio
My wife's Jeep Cherokee
I found this Door holder idea on the inter webs for a Jeep and decided to utilize the plans for my 4 door bronco.
4 - 10' X1" PVC pipe
 schedule 40
6-1" pipe insulators
 (black foam)
14 - 1" PVC elbows
10 - 1" PVC TEEs
1 - Can of PVC cement
Cut the pipe into 10 - 2 foot sections,
 8 - 4 inch sections,
and the rest into 1 foot sections. use the images above to copy the assembly. Message me for more info if you have questions.
What is the width of this? The instructions indicate 1 foot sections but it appears to be longer than that and would also need to be in order to mount to the dolly's pictured later. Thank you
RFMETZ
Ryan
Lakewood, CO
GX460
Not sure if this has been posted and people may not want to spend this much but this is one of the best solutions I've seen on Etsy.
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
Pretty slick. Do you have the design revised for a 2-door setup? Also, have you found anything similar for the roof and roof panels? Thanks!
No Sorry i didnt mess with a 2 door design. I am sure you can build this style and use 2 of the slots for the roof panels.
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
I dont know off the top of my head. I can get pics of measurements later
VelocityBronco
E
Thanks for the guide! I changed it up a bit and made a rack for just 2 doors. Plan to do another rack for the other 2. More material and cost, yes, but easier to store and move around.
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle PXL_20220529_192845249
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle PXL_20220529_214839814
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle PXL_20220529_214847845.MP
Kyukidoeric
Panama City Beach Florida
2022 Bronco (former 69 & 77 Bronco owner)
This is exactly what I've been thinking. But 2 racks for my 4 door. My space is limited so having to racks will be less bulky. Thanks guys for posting this. I had this plan in my head, but now, all I need to do is copy your specs.
VelocityBronco
E
I am mid build on the 2nd cart for the back doors but need more PVC and foam. Building 2 carts needs more material, so you'll need 5 10' sticks of pipe and 8 sticks of foam.
I also made mine a couple inches wider in both directions.
Kyukidoeric
I was just pricing. It looks like PVC pricing has risen so much. It looks like an $80 build, when I was expecting $20. But I can't wait to get started.
VelocityBronco
E
The fittings really add up too... I'm over $100 easily for 2 carts.
but I needed somewhere to put my door, and I'm not putting them on the ground or somewhere where the kids can knock them over.
Kyukidoeric
Yes. For sure.
Today I made a bag for my window after I take them off. It has a large pocket for the back window, and 2 smaller pockets for the side windows.
I'm still debating on making the door bags after completing the rack. I might just leave that alone.
Is everyone aware that you can take off all the windows without opening any doors, including the back door. Meaning... With your soft top Bronco locked up, the windows slide off with ease in under 2 minutes for all. Even the back window slides off without opening the rear tailgate.......
Not a good security measure.
RedHotFuzz
2022 Bronco Black Diamond 4D
Great Idea I think using those HF dollies ... I want to do the same but something that holds the ROOF panels. !!!
I’m going to put a T connector on the corners of mine and use casters with 1” inserts.
VelocityBronco
E
Yes. For sure.
That's cool you are making your own bags. I just bought the window bag from Mabett.
I knew about the back window security flaw. Pretty strange I agree. I just took all 3 windows out and put them back in without opening a door...
