NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
I found this Door holder idea on the inter webs for a Jeep and decided to utilize the plans for my 4 door bronco.
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle IMG_6236
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle IMG_6237
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle IMG_6238
4 - 10' X1" PVC pipe
 schedule 40
6-1" pipe insulators
 (black foam)
14 - 1" PVC elbows
10 - 1" PVC TEEs
1 - Can of PVC cement
Cut the pipe into 10 - 2 foot sections,
 8 - 4 inch sections,
and the rest into 1 foot sections. use the images above to copy the assembly. Message me for more info if you have questions.
shoelessjoe
2013 Chevy Cruze
 schedule 40
 (black foam)
14 - 1" PVC elbows
10 - 1" PVC TEEs
Mount some wheels to that bad boy!!!!!!
bandwagon
LaVista
2021 Badlands 4 Door
Would probably recommend mounting on 2x4s/plywood to give it a good base for wheels
I havent glued mine together - the full coverage foam is nice!
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle 6D4C5134-3CF5-41F4-9EC0-3BC4362E0FFC
straycat
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
I did this as well, added wheels to mine though.
It does take a lot of garage real estate, so I may be looking into a wall mounted storage option soon.
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle IMG_5595
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Love the idea! Looks awesome!
If you're going to add wheels, you may want to add a simple strap that goes around the entire thing. Last thing you want is to catch a small rock and then the doors go flying off... Yikes!
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle giphy
atx_chance
Chance
Austin, TX
Previous: 1993 Bronco XLT
I'm very interested in a wall mounted option b/c space is so short in my garage... But not the $200 one on Etsy. I think like $80-$120 is a more reasonable price for that... Healthy profit but not losing sight of the fact that it's a small piece of metal with holes in it allowing the wall mount.. haha
