I just use the key fob. I haven't even tested out the button other than noticing it reacts when I brush my microfiber cloth over it.The unlocking is flawless and works like you describe. I just can't get the thing to re-lock after exiting a lot of times.
Not at all true.True, but partially incorrect-
EDIT: For some reason, these handles require a touch of the inside portion before touching the lock button. Sort of like an "unlock clear" thing
-Sincerely, Trim engineer
I like being able to leave my fob in my pocket at all time though, and I'm used to locking with the 7/8-9/0 buttons with a keypad so the "button" on the handle feels like a very natural evolution of that.I just use the key fob. I haven't even tested out the button other than noticing it reacts when I brush my microfiber cloth over it.![]()
I started doing that, just tapping it and keeping the rest of my hand away and it's been working. The wrap around seemed to be the cause of my issues.Not at all true.
I have been simply tapping the lock nub on the outside of either the driver or cargo door handle and successfully locking the vehicle just fine. You do not need to grab the handle.
That's how I thought it worked and what I did for the first week. Turns out I was just leaving it unlocked.You shut the door and as you walk away the car honks and it locks itself. You walk back up to the car press the button on the handle and it unlocks. Keys never have to come out the pocket.
I started doing that when pushing the button on the front of the handle does nothing. In fact shouldn't that just be a dummy cover for manual key operation?I just press the door lock button on the inside of the door as I'm exiting and shut the door. Works every time.
