Door alignment issue, looks like its not fully closed.
broncobase1
Lincoln
22 Bronco Base
Update! Dealer body shop got it all straightened out.
The rear edge of my passenger door sticks out a bit, like its not fully closed. Its minor but quite noticeable when looking down the side of the Bronco. The dealer said its a hinge alignment issue, does this make sense? The stick out is the full width of the door, not just the top or bottom. Also there is no alignment issue with the front of the door and the front fender. It seems to me this would be a striker or latch issue. I would like to get it corrected, but do they really know what they are doing? Anyone else have this issue, and can it be corrected by adjusting the hinges?
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
It’s possible. Should be warranty
zombie
New Brunswick, Canada
If you're comfortable doing so, try taking the door off and put it back on.
shoelessjoe
2013 Chevy Cruze
It is either the latch or striker. If they have a body shop at the dealership call them not the service/repair department.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
Also remember that the rear fenders are removable, which means they may have a small amount of adjustment as well. Could be a little striker/latch, could be a little fender alignment, could be a little of both. Just an idea. Either way, if its quite noticeable, seems like it should be covered by the factory warranty if you just picked it up.
Area51_BADLANDS
Toronto
2023 Heritage Limited REB
You can loosen latch plate possibly and tap with rubber hammer and push it in 1/16 inch then lock it in place ! Door adjustments should have been caught by dealer during PDI !
Lifeliberty
Moonbeam👀
Columbus, OH
I don't know what you guys are talking about, it looks closed to me🤷‍♂️
