XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Edit: Full installation post
My Flex needs a windshield replacement. Considering they're going to swap over the rain sensor to the new glass anyway, figured this was a good opportunity to test it on the Bronco. A rough test with dangling wires and the sensor crudely stuck onto the windshield was enough to determine that the Bronco does support rain sensing.
Wiring is simple: Power, Ground, and LIN. The LIN needs to tap into the yellow/grey wire running between the SCCM and wiper motor. Easiest access is by removing the steering column shroud (3x 7mm screws). On the sensor, Pin 1 is accessory power, Pin 2 is LIN, Pin 3 is ground.
Parts (pick one from each group):
You also have the option of visiting the junkyard to get the sensor, bracket, cover, and pigtail. Be careful not to get the sensor gel dirty, replacement gel is half the cost of a brand new sensor.
I tried using Cricut software to cut the vinyl but it's not an easy program for me to figure out. I ended up using my 3d printer as a vinyl cutter instead.
AsBuilt changes were all done through easy mode.
  • SCCM: Rain Sensing Wiper [ENABLE]
  • SCCM: Rain Sensor [ENABLE]
  • APIM: Rain Sensing Wiper [ENABLE]
With the sensor stuck to the windshield and AsBuilt changes made, I turned the wiper control to Intermittent. It performed one wipe, then waited ~15 seconds and parked the blades. After that it was ready and responded as expected to water hitting the sensor! A heavier mist would result in faster wiping. If no water is detected after ~30 seconds, it parks the blades.
When the 'Rain Sensing' option is turned off, the intermittent stalk positions work like factory.
When the "Rain Sensing' option is turned on, the intermittent stalk positions adjust sensitivity, with Constant Slow and Constant High still overriding like factory.
Now that we know the Bronco can support it, I have to make it look good.
Things get a little trickier at this point.
First problem: The masking around the rain sensor in factory applications. This one should be an easy fix, a little Oracal 651 permanent vinyl, trimmed to match the correct shape and applied to the inside of the windshield. This is exactly what I did on the Flex to add lane-assist. From the outside it looks similar enough to the normal black masking. A Cricut is probably needed to get a perfect circle.
Second problem: The mounting bracket. You can't buy these from the dealer or official parts sites, they're considered integral to the windshield. Your options are junkyard pull, 3D-print, CNC, or buy a replica bracket off Aliexpress.
So that's where I'm at right now. Proof of concept worked, now time to make it look relatively factory.
I'll order a sensor and design the bracket/vinyl template, updating this thread as I do so with more details.
Ford Bronco [Done] Rain-Sensing Wipers Installed PXL_20231115_232749128
LIN wire in steering column. Luckily it's the only mostly-yellow wire that isn't in a twisted pair, making identification easy.
Ford Bronco [Done] Rain-Sensing Wipers Installed PXL_20231115_233804330
A more likely location
Ford Bronco [Done] Rain-Sensing Wipers Installed Vinyl
Oracal 651 vinyl stuck to the inside of the Flex's windshield to mimic the masking on cars that normally have lane-assist.
FleshTuxedo
A
PA
'22 OBX 2dr.
Whoa! Awesome!
adamruiz2001
SoCal
Ford SVT Lightning
Well I be damn, now this is what I am talking about, nicely done sir! 🍻
CrazyPete
Buffalo, NY
2018 GMC Denali 2500HD Duramax
Very cool. I was very surprised to learn that my 23 Wildtrak Lux didn't come with this already.
RagnarKon
Ford Bronco, Escape, Focus
Very cool!!!
I’ll admit I am the type of person who despises rain-sensing wipers and have always disabled the functionality.
But still very cool. Nice work!
XirallicBolts
XirallicBolts
Xira
Midwest, USA
Hoping I didn't botch it with ordering parts. I was in a bit of a rush and ordered a LU5Z-17D547-A instead of -B.
Looking closer, it appears the only difference is -A has the retainer perpendicular, -B has it angled. It seems they use the same sensor and retainer for both applications, the -A and -B denoting what angle they attached the retainer.
I'm sure this has to do with how some models would have the rearview mirror mount double as the rain sensor mount, while others had a dedicated rain sensor bracket.
Easy fix, at least. This must be a newer change because my old rain sensor didn't have a permanently-attached retainer.
Ford Bronco [Done] Rain-Sensing Wipers Installed Untitled
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
Thank you! Not that I want rain sensing, but I like adding functionality... on the F150 Forum, XLariaT and BoostedGreyGoose modified their XLT's with upper trim functionally... I'd like the Braptor paddle shifters please. My truck (XLT) has a Raptor steering wheel with functional paddles 😁, I use them when Im driving twisties.
aniljavali
Anil
Plainfield, IL
www.youtube.com
Bronco Badlands '22 & Tesla 3
thats cool, it will be an amazing upgrade to the bronco. saving this post for now.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
This is fantastic, definitely watching this thread for future progress!
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
My Flex needs a windshield replacement. Considering they're going to swap over the rain sensor to the new glass anyway, figured this was a good opportunity to test it on the Bronco,
Between this and the post about getting lane centering, I'm hoping one day I'll be able to get both of these done to get the full what-should-have-been LUX package!
JBlanco
Julio
Charlotte NC
If it involves hacking and 3D printing, I'm in!
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
This is some quality content, thank you
AKBronc49
Russ
Anchorage, Alaska
I love this!
