CrazyPete
Buffalo, NY
2018 GMC Denali 2500HD Duramax
Great work and something I'll consider. The only real issue i have is with the constant window cracking these Broncos have and this just being one more thing to deal with. 🤷‍♂️
Y2KFirehawk
PA
2022 Bronco Wildtrak
Every time I drive in the rain and touch the wiper controls, I think of this thread.
Mtea
Marty
Idaho
2023 2dr 2.3 Auto, Porsche Cayenne Diesel Platinum
Certainly nicely done, but I live in farm and bug country. Every time I pass by a field with a huge sprinkler going and my windshield dotted with splattered bugs I am SO glad my Bronco doesn’t have rain sensing wipers to automatically spread bug guts over the rest of my windshield.
lapazleo
Indiana
2022 bronco badlands
It's a convenience feature.
Like power windows, push-to-start, power locks, automatic headlamps, e-lockers, speed-sensitive volume, or the way your turn signal cancels after you've completed a turn.
Instead of having to temporarily speed up your wipers when passing a semi or manually doing a single wipe when a passing car kicks up slushy snow, it's a nice little convenience to keep from having to fiddle with the wiper setting every couple minutes.
Have human beings really become that lazy?
JBlanco
Julio
Charlotte NC
2023 Bronco BaseSquatch, 2023 Tesla Y Performance
Says the guy driving a vehicle instead of walking... Seriously, this types of unnecessary replies that don't contribute to anything are getting boring, like a child throwing a tantrum just to get attention.
wisaabi
Bob
Tacoma, WA
Finally bit the bullet and went for the full install.
Immediate lesson learned: The sensor window should've been 31mm, not 35. I'll wait until it's warmer to redo the vinyl. Doesn't seem to affect performance, just results in a silver ring around the sensor when viewed from outside. I also should've had the right edge come down lower to match the factory fritting, but I couldn't tell exactly where it was with my dashcam mount in the way.
Photos in the next post for clarity.
Thingiverse: Printable parts and templates
1) Cut a piece of Oracal 651 matte black vinyl. Either hand-cut using a printed template, or use a vinyl cutter such as Cricut. The sensor window should be 31mm in diameter.
2) Remove the rearview mirror. Thank God Bronco uses a T20 setscrew, I've broken multiple windshields trying to remove the older spring-style mirrors.
3) Thoroughly clean the windshield area with iso alcohol
4) Attach the vinyl to the windshield, ensuring none of the ceramic dots are visible in the sensor window. Avoid touching the sticky side around the sensor since it'll be visible from the outside. It's pretty safe to touch the top half though; that's mostly obscured.
5) Cover the dashboard with an old blanket.
6) Mix JBweld, apply to sensor bracket in a thin, even coat. The single-tube 'High Heat' may be ok for this application, but I prefer the two-tube grey style.
7) Attach bracket to windshield, keyway pointed up, centered on that sensor window. Use tape to hold it in place overnight
8) Prepare your wiring harness. Three wires, maybe 6 feet total length. A Dupont female connector will work just fine. Pin 1 is +12v, Pin 2 is LIN, Pin 3 is Ground. I used Red, Orange, and White/Red respectively.
9) After the JBweld has cured overnight, attach the new rain sensor. I was worried about the metal retainer pressing too hard and ripping the vinyl off the windshield, so I bent it nearly flat to reduce the pulling force. I'd rather the sensor be somewhat friction-fit into the mount than use the retainer to hold it in place.
10) Attach your wiring harness. When the sensor is installed, Ground is to the left, +12v is to the right. Route the wires down the A-pillar and to the fusebox similar to how a dashcam would be wired. I followed the path/procedure used by the IAG interior light kit, though easier options are available. (IAG guide, just follow the parts related to driver A-pillar)
+ Remove hardtop front section
+ Remove the plastic trim piece at the roof panel latch (two clips)
+ Remove two screws along driver rollcage (8mm, where the Bartact handle attaches)
+ Pull trim towards center of car. Doesn't need to be removed completely.
+ Remove A-pillar trim with 'AIRBAG' embossed.
+ Remove dashboard grab handle at the driver's door
+ Remove trim piece between the dash and driver door
+ Sneak wires behind airbag and down to the fusebox area.
10a) Alternatively, just tuck the wires into various trim pieces running down the A-pillar. My dashcam wiring was already taking up that space so I had to do the full method above.
11) Remove steering wheel column shroud.
+ Pull lower panel (the one with the headlamp switch) from the top, it rotates down to the floor and blocks the pedals.
+ Three 7mm screws on the bottom of the shroud
+ Pull on the bottom shroud to start disengaging clips
+ Turn the steering wheel to the 3:00 and 9:00 position to access last two clips between the shroud and wheel
12) Carefully remove some of the microfiber tape protecting the wiring harness leading to the steering wheel. There should be a yellow/grey wire. Remove a bit of insulation, attach your LIN wire to this. For future convenience, I soldered a 6" piece of wire with a quick-disconnect.
13) Provide accessory +12v power to the sensor. I tapped it into my dashcam wiring, which comes off an Add-a-Fuse. I don't recall offhand which fuse it taps into, but there's a plethora of accessory wiring threads on this forum.
14) Reassemble everything, attach rain sensor cover.
15) In Forscan, change the Easymode settings
SCCM: Rain Sensing Wipers [Enabled]
SCCM: Rain Sensor [Enabled]
APIM: Rain Sensing Wipers [Enabled]
The setting can be found on your touchscreen under Settings > Vehicle > Wipers > Rain Sensing.
That's really all there is to it! Total install time was maybe an hour, not counting the time spent letting the JBweld cure.
Took a drive today in a light snow and it responded as expected. When following a car, it'd wipe more frequently. At stoplights, it never wiped because the falling snow was very light.
Do you have a template for the vinyl that could be emailed and printed to paper? I was planning on cutting it out by hand using the cover as a guide but the hard part is locating the hole for the sensor.
XirallicBolts
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Thanks, I kept forgetting to finish figuring out the templates. Luckily I found a plugin for Fusion 360 to export the sketches as SVG because Inkscape, Krita, Cricut, and all the rest of the Illustrator-style programs suck.
Templates in SVG format are attached as a ZIP below, as well as uploaded to the Thingiverse page. I'm not an expert on SVGs but it should print at the correct size. The vinyl template is slightly larger than the actual cover by 2mm. I wanted a little wiggle room so the edge of the cover can't be seen from outside.
I'm noticing on my most recent install, I can actually see the mounting bracket from outside the vinyl. I think what is happening is, I used the 'steel reinforced' JBweld and the steel particles might actually be pushing their way through the vinyl. The clear High-Heat JBweld might be a better choice. Edit: Or, more likely, I'm seeing little pockets of air as the vinyl gets pulled away from the glass. I'll have to find that happy medium where the sensor is squished against the glass hard enough, but not so hard as to lift the vinyl. That or a completely different bracket that spreads the forcebetter, at the expensive of compatibility with OEM covers.
Ford Bronco [Done] Rain-Sensing Wipers Installed Untitled
This is not the template, just a visual example of the intentional gap between the cover and vinyl. Download "SVG Templates.zip" below for the actual printable files.
wisaabi
Bob
Tacoma, WA
Templates in SVG format are attached as a ZIP, as well as uploaded to the Thingiverse page. I'm not an expert on SVGs but it should print at the correct size. The vinyl template is slightly larger than the actual cover by 2mm. I wanted a little wiggle room so the edge of the cover can't be seen from outside.
This is awesome, thanks!
KhoiPhish
Altima
Between this and the post about getting lane centering, I'm hoping one day I'll be able to get both of these done to get the full what-should-have-been LUX package!
which post was that?
wisaabi
Bob
Tacoma, WA
For, "8) Prepare your wiring harness. Three wires, maybe 6 feet total length. A Dupont female connector will work just fine. Pin 1 is +12v, Pin 2 is LIN, Pin 3 is Ground. I used Red, Orange, and White/Red respectively"
What is the orientation of the sensor and are you reading pin 1 to 3 left to right?
XirallicBolts
XirallicBolts
Xira
Midwest, USA
The pins are numbered inside the body, though it's incredibly tiny.
When the sensor is attached to the glass, connector facing towards the roof, the pins are arranged, left to right: Ground, LIN, Power. The connector diagram is pretty vague, so hopefully this is clearer:
Ford Bronco [Done] Rain-Sensing Wipers Installed IMG_1919
mpeugeot
XirallicBolts
XirallicBolts
Xira
Midwest, USA
Five-month update.
Electrically, it's been working fine.
Visually, the vinyl kept trying to pull away from the glass, resulting in a visible pattern on the outside in the shape of the bracket. Of course, I somehow failed to get any pictures of this.
My thought was to switch to a two-layer setup like I'm doing in the Flex -- apply glass primer to the windshield, then a layer of vinyl over it. My thought was the vinyl might stick better to primer, and any air pockets would be hidden. I had my camera all set up so I could record a full howto on the installation.
Well, applying the primer didn't go as planned and on the third attempt, spilled it all over my hands. The gel on the rain sensor also got pretty messed up, so I have more shipping from aliexpress ($6 for eight vs $35 for one on Amazon)
Decided to modify the bracket design. The first version was meant to replicate the OEM bracket 1:1 so it'd be compatible with OEM covers, with an optional 'shorter' cover that would have to be printed.
New design increases the surface area but isn't directly compatible with OEM covers. Maybe it'd work if you broke the tabs off.
I also got nervous about having too much surface area because I broke the Flex's windshield using epoxy over too large of an area. Instead, I used high-temp VHB tape to apply the bracket this time. Dialed in the vinyl template design a little closer, too.
So I guess we'll see again. The increased surface area should hopefully help prevent pulling away. If I can find one of my spare rain sensor covers, I'll see if it can attach directly to this mount. I'm honestly hoping so, because I haven't found a good way to print the cover that didn't result in an obvious '3d printed' appearance.
Also debating having the first layer of vinyl being properly shaped to match the existing frit, then put three or four additional 'rough" layers just where the bracket mounts for extra strength. I can already kinda see where the tape is, though that could just be from the vinyl still needing to even out
Ford Bronco [Done] Rain-Sensing Wipers Installed PXL_20240517_235814402
Y2KFirehawk
PA
Five-month update.
Thanks for staying hungry and continuing to iterate! We are all reading with baited breath :)
